JohanSA
Best SD cards for 24x7 use
Mon Aug 05, 2013 9:52 am
Hello
I use the raspberry pi on a 24x7 basis. I seldom switch it off. Which SD card is the most sustainable for 24x7 operation. Kingston have adviced not to use the card for 24x7 because it will wear and tear relatively quickly.
any suggestions?
itimpi
Re: Best SD cards for 24x7 use
Mon Aug 05, 2013 10:06 am
If you want the most reliable operation there is an excellent case for holding the root file system on a USB stick and only use the SD card for booting. The very nature of SD cards is that they have a limited (albeit quite high) number of write cycles they can support. You can get micro USB drive that hardly protrudes from the USB socket. You would also only need a very small SD card as only the boot partition files would then need to reside on it.
JohanSA
Mon Aug 05, 2013 10:11 am
Thank you. I never considered using a USB. Something worth trying out!
RaTTuS
Contact: Twitter YouTube
Mon Aug 05, 2013 10:14 am
pffth
I've had 1 RPi running on the same SD card for a year now
 uprecords
     #               Uptime | System                                     Boot up
     1    71 days, 22:59:51 | Linux 3.6.11+             Tue Mar 12 08:37:44 2013
     2    32 days, 17:49:08 | Linux 3.6.11+             Thu Jun 20 17:30:57 2013
     3    30 days, 05:03:22 | Linux 3.2.27+             Wed Dec 12 12:26:21 2012
     4    27 days, 18:56:43 | Linux 3.6.11+             Thu May 23 17:35:40 2013
     5    22 days, 23:26:51 | Linux 3.2.27+             Sat Nov 17 17:55:38 2012
     6    18 days, 05:55:29 | Linux 3.1.9+              Fri Aug 10 11:23:26 2012
     7    17 days, 00:47:44 | Linux 3.6.11+             Mon Feb 11 16:24:05 2013
     8    13 days, 20:10:25 | Linux 3.2.27+             Thu Sep 20 16:53:12 2012
->   9    11 days, 22:34:57 | Linux 3.6.11+             Wed Jul 24 12:35:39 2013
    10    11 days, 04:54:32 | Linux 3.2.27+             Fri Oct 19 08:39:20 2012
1up in     1 day , 21:35:29 | at                        Wed Aug  7 08:46:04 2013
no1 in    60 days, 00:24:55 | at                        Fri Oct  4 11:35:30 2013
    up   365 days, 08:09:15 | since                     Tue Jul 17 12:46:07 2012
  down    18 days, 14:15:14 | since                     Tue Jul 17 12:46:07 2012
   %up               95.157 | since                     Tue Jul 17 12:46:07 2012
no issues with the SD card [well.... ]
but if your worried you can put the rootfs on an external HD / USB drive, it's not really necessary
Covfefe
JohanSA
Mon Aug 05, 2013 10:16 am
Do you reboot the SD card every once in a while?
RaTTuS
Mon Aug 05, 2013 10:26 am
mainly for updates and to add stuff - this RPi has a texy LCD screen on it also though there have been a few power cuts where it lives
I also tend to use it for developing random stuff; it's an original version
[I have 4 RPi's in general use]
1 as a media center [rootfs on ssd - for size and quietness]
1 as a surveillance system [with camera and rootfs on a 650GB 2.5" drive ]
1 Model A as a test / camera system
1 red raspberry Pi as a general testing system - currently hooked up to the model A via serial leads
the ones with the root fs on an external HD have a slightly more responsive feel to them .
I'd not use a USB stick as rootfs personally - extra space maybe ...
as for life of sd cards,
I've got a 16Gb on in a car DVR which has been working for 6mnths and that gets re-written completely about once a day
late edit.....
use it and see how long it lasts for you
Covfefe
solar3000
Mon Aug 05, 2013 2:21 pm
JohanSA wrote:Hello
any suggestions?
but all my phones and tablets have SD cards in them all the time.
why would it be a problem keeping them powered on all the time?
phones keep the cards connected all the time.
the only time the card wears is when it is written to.
dont worry about it.
I have five pis and I never turn them off.
Antikythera
JohanSA
Fri Aug 09, 2013 6:50 am
solar you are right. A smart phones uses the micro SD and I have never heard of it corrupting.
That means that maybe it has something to do with the software
ghans
Fri Aug 09, 2013 8:01 am
AFAIK the rootfs of a mobile phone OS does seldom
reside on a SD card (which vary wildly in quality) ... and
for example Android uses special filesystems like YAFFS , JFFS or
F2FS . I think if you use an additional SD card the separation
of user data and OS helps. And mobile OS are designed with
Flash wear in mind , not like Debian for spinning disks.
ghans
Davespice
Contact: Twitter
Fri Aug 09, 2013 9:19 am
You can also have a look through this list;
http://elinux.org/RPi_SD_cards#Working_ ... g_SD_cards
I have a class 4 SD card from Jessops which runs a 24/7 Pi. Although most of the time it's idle.
