jeroq
Ethernet don't work whith Graphic system
Sat Aug 03, 2013 4:46 pm
I have a Raspberry pi whith 512 Mb
Jun 17 2013 20:49:11
Copyright (c) 2012 Broadcom
version d380dde43fe729f043befb5cf775f99e54586cde (clean) (release)
Every time I run graphical environment I lose ethernet connection.
From console I don't have problems, I downloaded the updates successfully.
The IP configuration is static.
When ethernet work' ifconfig reports said:
eth0 Link encap: Ethernet HWaddr b8: 27: eb: cb: 92: ea
inet addr: 192.168.1.99 Bcast: 192.168.1.255 Mask: 255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU: 1500 Metric: 1
When the graphical environment works, you lose the second line settings
and also the connection
Thanks in advance
itimpi
Re: Ethernet don't work whith Graphic system
Sat Aug 03, 2013 8:15 pm
What is the power supply you are using rated at? This can be a symptom of a power supply that cannot provide sufficient current as loading the GUI increases the total current required.
jeroq
Wed Aug 07, 2013 8:16 am
I have a power suply Rome travel charger,
Input 110/240 V 50/60 Hz 100 mA
Output DC 5.0 V 1000 mA
Made in China
this malfunction occurs also when I access via SSH and run VNC or when I access through remote desktop, note that no devices are connected to the USB ports.
Sometimes I navigate a few seconds through the graphical environment.
thanks
