I've seen this sort of thing advertised on on the web:
http://denkovi.com/product/31/.....ver-1.html
It says it appears to a PC as a standard COM port and you write commands to control the relays. I assume that would be the same for the PI?
Would the PI be able to interface with this easily? I assume you'd need a linux driver for the USB Com port and then a simple client to send the commands to the COM port itself.
Obviously you'd need to supply the board with a separate 12V feed to power the relays.
I realise the PI has a set of GPIO pins, but is using the USB inerface for control work also a viable possibility?
- mahjongg
- Forum Moderator
Re: Would the PI be able to control something like this? (USB Relay board)
mc349 said:
I"ve seen this sort of thing advertised on on the web:
Would the PI be able to interface with this easily? I assume you"d need a linux driver for the USB Com port and then a simple client to send the commands to the COM port itself.
Obviously you"d need to supply the board with a separate 12V feed to power the relays.
Yes, its also a viable solution, if you do not mind the cost, and the slight delays induced by sending commands over a serial port USB connection to a microcontroller. These delays are probably insignificant compared to the switching speed of the relays.
I'm not sure such a solution would be acceptable in an industrial control design though.
Youd be better off getting something like this http://www.ebay.co.uk/itm/8-Ch.....4601afdd9c and interfacing to that out of the GPIO.
It would be far cheaper.
That board seems to have a 5V input, the Pi GPIO pins are 3V3.
Velleman do some useful USB I/O boards and kits that may be worth a look. K8055 rings a bell.
Hence me saying "and interfacing to that"
IMO it would be far cheaper to do that and use another board than spending $91+ on it.
I think it's worth stressing the 3V3 nature of the GPIO, it's easy to imagine people frying their Pi, and connecting a few wires could be thought of as an interface.
The Velleman kit is £20:
http://www.amazon.co.uk/USB-ex.....038;sr=8-1
There's a Linux interface:
http://libk8055.sourceforge.net/
I've not used this exact one but the Velleman kits I've bought seem to be good value.
While the velleman kits are good they are not doing what the OP asked for, to be able to control relays.
So a relay board at £10 and a fivers worth of interfacing to it is IMO a far better hobbyists solution. In fact the relay board could always be modified to take 3v3 instead at its inputs.
Linux has support for USB to serial built into the kernel. So no real problem there. The problem may be finding software to talk to the board. There are several Linux programs that may work.
512MB version 2.0 as WordPress Server
Motorola Lapdock with Pi2B
Modded Rev 1.0 with pin headers at USB
http://rich1.dyndns.tv/
(RS)Allied ships old stock to reward its Customers for long wait!
Thanks for all the help & suggestions. I can handle the software side of things I think (as long as I've got a driver that's working), it's simple in linux to write data to a serial port.
It's the electronic side of things that has me more worried. If it works it looks like the $90 board I linked to would just plug into the PI and no further soldering / circuit design would be needed on that end of things. All the connections look like screw connections. I'm interested in controlling lights/ heating pumps / motors, general home automation type things. so speed of switching (speed of USB serial interface) wouldn't be a concern, I'm not trying to steer a rocket or anything.
I might buy one of their smaller (cheaper) USB boards to see if I can get it working and then upgrade to the larger one (more channels+ higher amperage capacity) later on.
I'm still patiently waiting for my slice of PI to arrive in any case...
In that case try the velleman USB board mentioned http://www.maplin.co.uk/usb-ex.....oard-42857 (they do an assembled one too) AND a relay board then, the USB board will be useful for other things including sensor inputs but I would also get a relay board for local switching to then control larger local relays and contactors.
When you have something working please come back and let us know how you got on with it.
P.S. the USB boards do not appear to have relay outputs on.
Personally if I was going to control a relay I"d use the GPIO, use an opto isolator with a darlington output and ensure the coil had a fly back diode. If you are feeling über clean then a snubber circuit on the contact output to reduce the possibility of arcing.
You could use the Gert Board and the driver.
Good Luck
Good Luck
Me too but it appears the OP wants a simple purchasable solution, for home automation some inputs would also be useful.
Maybe openremote.org will be a solution, if Java is running fine on the Pi and the RXTX lib can be compiled.
OpenRemote is strongly looking into using the Pi as a low cost 24/7 controller box for home automation.
Unfortunately we are still waiting on our first delivery.
- gordon@drogon.net
- Contact: Website Twitter
Yes. These sort of things should work just fine – if you write your own serial handler which is relatively easy to do. I've used several USB power switchers in the past, none on the Pi (yet), but there's no real magic about them.
Quick edit - if the commands you sent to it are text commands, then you can experiment and test it with minicom - which is a decent serial terminal program for Linux. I use it for a lot of serial testing myself - mostly via usb serial devices like modems, GPSs and Arduinos!
Gordon
Gordon
Good Luck
Now you're just showing off! I do need to learn all this stuff. :-)
Good Luck
MC, what is it that you actually want to control with this?
What responses do you expect from sensors etc?
I am going to look into 1-wire to do interfacing and sensing. You can get some of the 1-wire components as 'samples' too.
The vallemen kit also looks good.
You may want to have a look here:
http://www.yoctopuce.com/EN/products/us ... octo-relay
USB, no driver needed, API available in most common programming languages, you even can use a PI to drive it.
You can have a look at the competition too : http://www.phidgets.com/
We produce USB controllers, USB sensors as well as embedded USB hubs for DIY projects
Hello
it is pretty simple to control USB Relais Cards using Raspberry PI. I got one of those boards from denkovi. It provides 2 Relays and is 5V powered via USB.
Here is the link to the source : https://github.com/df3xc/libftdinet
The solution is useful for C, C++ and C# programming. But the Basic operations (set the FTDI device into bit bang mode, read and set the Relais are available in other programming languages too. Just search the Internet)
Refer to the wiki on the project page for installation instructions.
About the source code:
Drivers from FTDI did not work for me,hence I used the open source driver libftdi.
Power of two function included (as .NET math operations give surprising results on hardfloat ARM Linux)
Kind regards
Kind regards
