I've seen this sort of thing advertised on on the web:
http://denkovi.com/product/31/.....ver-1.html
It says it appears to a PC as a standard COM port and you write commands to control the relays. I assume that would be the same for the PI?
Would the PI be able to interface with this easily? I assume you'd need a linux driver for the USB Com port and then a simple client to send the commands to the COM port itself.
Obviously you'd need to supply the board with a separate 12V feed to power the relays.
I realise the PI has a set of GPIO pins, but is using the USB inerface for control work also a viable possibility?
