Boddah
Lost TightVNC password ...
Sun Jul 28, 2013 9:33 pm
hi all, ive recently started using my raspberry pi again and have since forgotten my password for tightvnc ive searched high and low on the internet for instructions on how to set a new one but i just cant find anything other than installing a new tightvnc, does anyone have the command line which will enable me to reset it or is it going to have to be a fresh install ?
mahjongg
Re: Urgent Help Needed !!!
Sun Jul 28, 2013 9:37 pm
I would start by changing the subject line to one that describes your problem, Just using "I need help" makes 99% or readers just skip your message, so start over, with a better subject line, or edit the current subject line.
Joe Schmoe
Re: Lost TightVNC password ...
Sun Jul 28, 2013 10:30 pm
I'm pretty sure the answer to this question is just: run vncpasswd
Or just find a file somewhere in your home dir named "passwd" and remove it.
P.S. I noticed (while researching this question) that x11vnc doesn't have the same sort of password setup as the other ones (the "normal" ones) do. It seems to take the password on the command line (which is, of course, a Bad Idea).
