beatmag
Re: USB HD and Samba performance
Sun Apr 22, 2012 7:20 am
Sorry if this has been asked before. But I have searched many times through these forums and pretty much couldn't find an answer.
I wanted to ask for those who are lucky enough to get a raspberry pi, if they can post the USB HD performance and also the SAMBA performance through the ethernet as well.
USB HD over SAMBA transfer speed:
Read and Write?
I understand that raspberry pi is for development use, but how feasible would it be to use it to run a SAMBA server 24/7?
abishur
Sun Apr 22, 2012 2:50 pm
I'm using a usb hard drive and accessing it via samba.  One caveat, I'm doing this with the Pi physically wired into the network but with my test machine using wireless (which I think is fair enough since that's how a lot of us will be doing this), nothing else is even turned on so nothing else is using the network.
I'm using Lan Speed Test to test this, it performs 1 write than 1 read as many times as you ask it to up to 100.
1MB = 1,000,000 bytes
First test:  100 read/writes of 1MB (I'm trying to simulate a lot of read/writing to see how the USB bus holds up
Time to complete writes: 50.30 seconds
Time to complete reads: 40.84 seconds
Second test: 100 read/writes of 10MB
Test failed as it caused a kernel panic
Dear forum: Play nice ;-)
rmm200
Sun Apr 22, 2012 4:30 pm
Kernel panic is pretty severe. Think memory got stepped on? Guessing the SoC has a DMA controller. Bad pointer?
rew
Sun Apr 22, 2012 4:31 pm
You're getting about 100Mb in 50 seconds, so about 2Mb/sec ?
This is with the internal SD card? I have the impression that the internal SD card interface is quite slow. I've seen it reach speeds of up to 4Mb per second, peak! The SD cards that I use reach speeds of 15Mbyte per second in the $3 Chinese SD card readers....
It could be that the SD card driver in the linux kernel still needs some optimizing.
Check out our raspberry pi addons: https://www.bitwizard.nl/shop/
abishur
Sun Apr 22, 2012 11:32 pm
Nope. I specifically said I was using a USB HD
zfh10
Sun Apr 22, 2012 11:39 pm
can someone please translate this performance for the non-nerds among us
nicknml
Mon Apr 23, 2012 1:32 am
The performance is fairly slow and unstable right now.
lewmur
Mon Apr 23, 2012 1:46 am
Compared to what?  Compared to an IPad?  Compared to a netbook with an Atom 1.6ghz processor?  Or compared to cheap tablet with an ARM processor running a 8ghz running Android?  IMHO, the last one is the only relevant comparison.
rew
Mon Apr 23, 2012 6:27 am
It seems USB "mass storage" access is buggy. At the moment it is so buggy that performance measurements crash before you get a reading.
I tried my SD card reader and that crashed. I have other things to do, so that's when I left it.
abishur
Mon Apr 23, 2012 12:16 pm
When you say SD card reader do you mean usb sd card reader, or the built in one on the R-pi?
nicknml
Mon Apr 23, 2012 12:17 pm
I want an 8GHz ARM processor!
beatmag
Thu Apr 26, 2012 11:32 am
has all the issues been resolved?
its been quiet in this thread?
lewmur
Thu Apr 26, 2012 12:07 pm
Me too!  Meant an .8ghz.  Ah those misplaced decimal points.
Kushan
Thu Apr 26, 2012 12:14 pm
Isn't the ethernet controller actually attached via the USB bus, so we're actually limited by the speed of USB in general?
If that's the case, that might explain why performance seems so poor when using a USB HD to transfer stuff via ethernet.
ArborealSeer
Thu Apr 26, 2012 1:07 pm
as i understand it from previous posts, that is correct.
Pi Status > Farnell, Arrived 24/5- RS, Arrived 1/6
lewmur
Thu Apr 26, 2012 2:46 pm
A single USB 2.0 controller can handle 60mb/sec.  The ethernet port is about 10mb/sec.  So that leaves 50mb/sec for the USB HDD.  You know of any USB HDD's that'll write that fast?  Not much of a bottleneck.
eshatohhin
Fri May 18, 2012 8:24 am
tested samba performance over ethernet using old 80gb IDE drive connected to pi using £2 USB 2.0 to IDE Adapter Cable from ebay:
write: ~9mb/sec
Cpu(s): 10.8%us, 57.3%sy, 0.0%ni, 0.0%id, 0.0%wa, 0.0%hi, 31.8%si, 0.0%st
Mem: 190836k total, 178756k used, 12080k free, 2412k buffers
Swap: 0k total, 0k used, 0k free, 156996k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
958 nobody 20 0 16980 3076 2320 R 78.7 1.6 0:53.96 smbd
31 root 20 0 0 0 0 D 9.0 0.0 0:09.75 usb-storage
read: ~7.5mb sec
Cpu(s): 5.5%us, 54.8%sy, 0.0%ni, 0.0%id, 2.3%wa, 0.0%hi, 37.4%si, 0.0%st
Mem: 190836k total, 178568k used, 12268k free, 2184k buffers
Swap: 0k total, 0k used, 0k free, 159348k cached
958 nobody 20 0 16980 3336 2584 R 72.1 1.7 0:20.71 smbd
31 root 20 0 0 0 0 S 18.8 0.0 0:05.26 usb-storage
For some reason writing is faster (usb-storage requires less cpu, so smbd can get the most of it)
After few minutes system crashed, i guess its related to the buggy usb driver as mentioned in previous post.
dom
Fri May 18, 2012 8:48 am
@eshatohhin
Have you updated your kernel (e.g.with hexxeh's firmware updater tool)?
eshatohhin
Fri May 18, 2012 2:31 pm
Thanks @dom.
Updated firmware as you suggested and all the packages.
Now the stability seems to have improved. Transferred 5 gigs back and forth with no problems now.
At first I suspected that the problem was caused by the lack of power, as my rasp is currently draining power from monitors usb port.
Pianist
Wed Jul 18, 2012 4:18 pm
eshatohhin wrote:tested samba performance over ethernet using old 80gb IDE drive connected to pi using £2 USB 2.0 to IDE Adapter Cable from ebay:
write: ~9mb/sec
read: ~7.5mb sec
When I transfer data from/to a Win-PC to the RaPi-smbd I only achieve up to ~800kByte/s, but not stable: sometimes it drops down to ~300 kByte/s. The cpu load is always below 30%.
eshatohhin, can you tell me which distri do you use? Did you do a firmware update? Other hints?
Thanks.
Pianist
Fri Jul 20, 2012 11:18 am
Short update:
I'm using Debian wheezy. Yesterday I installed the hexxeh's firmware update. After that everything stayed the same: most time just 300 kByte/s.
So I did an package-update with aptitude (took ~1.5 hours). After that my throughput raised up to 1MByte/s. Samba-d is much more stable now. Even no big lags anymore when using a 2nd Win-Explorer to browse directories.
If someone has an idea how to increase speed once more, I'd be glad. ;-)
evil
Mon Jul 23, 2012 11:29 am
I tried the debian squeeze image yesterday and I got 7,5 MB/s read and 5,8 MB/s write performance (samba and windows 7).
Writing was first very instable - then I change the max_sector value from 240 to 480 .
cat /sys/block/sda/device/max_sectors
>240
echo 480 > /sys/block/sda/device/max_sectors
After that it worked stable for the next few test copys.
This ist a huge disappointment! USB and Ethernet on the same USB-Port I expected poor performance, but this result is really bad.
obarthelemy
Mon Jul 23, 2012 11:36 am
I've done half a dozen of tweaks to mine, which I jotted down somewhere and promptly lost.
For large files, you can leverage:
3.5 Readahead
The option readahead IS NOT the same as multcount. The multcount refers to the possibility of the hardware to read more than one sector at a time while the readahead option is the number of sectors ahead your computer should read. The readahead feature is great when reading big-size files but it brings down the performance for short-size files. A good idea is to leave the value of readahead the same as the multcount so it will not be needed to make more than an access per time to read more sectors ahead.
If you are going to access big files you can set the readahead to a greater value. The default value is 8 sectors/read access (something like 4kb).
Now the syntax:
# hdparm -a N /dev/hda
N is the number of sectors for readahead.
There's a setting somewhere to cache more in RAM too, or rather, to queue stuff in RAM then write it in one fell swoop instead of thrashing like crazy on the HD... I'll come back when I find it
evil
Mon Jul 23, 2012 11:38 am
>240
evil
Mon Jul 23, 2012 11:39 am
>240
