jonny789
wifi without usb hub needed
Thu Jul 04, 2013 12:55 pm
I need a wifi dongle that doesnt need a usb powered hub. I m gonna run my pi headless.
After searching on net. I found best ones : Airlink 101 Wireless N 150 (AWLL5099) , Edimax EW-7811Un USB WiFi
But these are out of my budget. Plz suggest me other wifi dongles that dont need hub & come under my budget upto- INR 750.
I m a bit confused- Which is the best one under my budget. I m concerned about compatibility with pi and most important-the performance & connectivity,network issues.
Davespice
Contact: Twitter
Re: wifi without usb hub needed
Thu Jul 04, 2013 1:28 pm
I'm not sure where you are looking at prices but on Amazon UK the Edimax one is less than £9.
http://www.amazon.co.uk/Edimax-EW-7811U ... B003MTTJOY
Is that any help?
kghunt
Thu Jul 04, 2013 2:36 pm
I have been using a nano wifi N dongle for almost 9 months with no external power source. I cannot remember what make it was but something like this.
http://www.ebay.co.uk/itm/New-802-11n-M ... 1e72271aae
jonny789
Thu Jul 04, 2013 2:47 pm
I m thinking to buy this one -TP-Link TL-WN722N.
Plz tell me- Can it run well without usb powered hub ?
Davespice
Contact: Twitter
Thu Jul 04, 2013 2:50 pm
jonny789
Thu Jul 04, 2013 2:54 pm
I just want to know that even if it happens to need usb hub..
Can I make it work without needing usb hub while running pi headless ??
cyrano
Thu Jul 04, 2013 5:07 pm
jonny789 wrote:I just want to know that even if it happens to need usb hub..
You can. There are a lot of people who us Pi's with just the USB Wifi adapter plugged in.
But nobody can tell you if THIS particular one will work. Even when it's the hardware specified by the type number, it might just draw a little too much current.
Don't worry, buy one of the suggested ones and test it with your Pi. And keep your fingers crossed :D
fredoll
Thu Jul 04, 2013 5:11 pm
If it can help you, I have used these 2 wifi dongles without a hub :
TP-Link TL-WN725N Nano http://www.amazon.fr/gp/product/B008B7PZU4 (very small but needs a specific driver)
TP-Link TL-WN721N http://www.amazon.fr/gp/product/B005LMM0L4 (bigger but support hostap mode)
pjc123
Fri Jul 05, 2013 11:15 am
jonny789 wrote:I m thinking to buy this one -TP-Link TL-WN722N.
I use this without a hub on my headless pi, but only on the Model B Rev 2 board. The Rev 1 Board requires that the USB fuses be removed or by using a "Y" splitter cable to draw power from both USB ports.
My Raspberry Pi Project Page:
https://www.flaminghellmet.com/launch/
SirLagz
Fri Jul 05, 2013 12:48 pm
Any generic RT5370 has worked for me.
PiGraham
Fri Jul 05, 2013 2:30 pm
Davespice wrote:I'm not sure where you are looking at prices but on Amazon UK the Edimax one is less than £9.
Is that any help?
That works for me, staright to Pi USB.
I also have two WiPi adaptors supplied by Farnell that also work directly connected.
This is on Model B rev 1 and Model a & B rev 2.
It may depend what power supply is used. If the voltage is marginal plugging in a USB load could cause problems.
dasimpson
Fri Jul 05, 2013 4:52 pm
awus036h (rtl1887) right from the pi usb port no problems
Knlgdgl
Tue Dec 30, 2014 10:48 am
fredoll wrote:If it can help you, I have used these 2 wifi dongles without a hub :
What is the rating of your Power Supply? I mean, how much amperage do you provide to the Raspberry Pi?
PalashTaneja
Tue Feb 24, 2015 1:45 am
Well the TL WN_721N works great for me without a USB hub you just have to plug it before boot. Also I have a tutorial for configuring it on my blog for anyone to check out.
https://thetechmaniacs.wordpress.com
shadowofdarkness
Sat Mar 07, 2015 7:37 am
Probably most will work if you raise the current to the USB ports.
I personally got the following results with the very popular and cheap ($12 CDN) TP-Link WN725N
When directly plugged into the PI under the basic setup I was only get LAN transfer speeds jumping around in the range of 1 - 2 megabytes/second but when I set max_usb_current=1 the LAN transfer speed jumped up to 11.2 megabytes/second which is the same my notebook gets and finally allowed me to stream raw Blu-Rays.
