Finding a path
Posted: Fri Jun 28, 2013 10:09 am
by martinrice
How do I find the path to a file?
Thanks.
Re: Finding a path
Posted: Fri Jun 28, 2013 10:17 am
by Pankoi
If you're in a terminal and in the same directory as the file, you can type 'pwd' to get the path to the current directory and then you should just be able to stick the filename on the end, if that's what you mean? :)
Hope that helps,
~Richard Williams
Re: Finding a path
Posted: Fri Jun 28, 2013 10:19 am
by joan
If you know the filename try
find / -name "filename"
If you know only part of the filename try
find / -name "*filename*"
Re: Finding a path
Posted: Fri Jun 28, 2013 10:23 am
by jamesh
Also, try the whereis command.
Re: Finding a path
Posted: Fri Jun 28, 2013 10:31 am
by RaTTuS
also
which
i.e.
which ls
Re: Finding a path
Posted: Fri Jun 28, 2013 12:40 pm
by martinrice
Thanks one and all for the help. It's appreciated!
Re: Finding a path
Posted: Fri Jun 28, 2013 1:18 pm
by dr_d_gee
If locate is installed (can't remember whether it is or not in the default Raspbian image) then
locate filename
will work. It uses a database of files so can produce results very quickly. If the database is not up-to-date you may need to do
sudo updatedb
first.
Re: Finding a path
Posted: Fri Jun 28, 2013 1:24 pm
by RaTTuS
locate is not included in the raspbian image but you can add it
Re: Finding a path
Posted: Fri Jun 28, 2013 1:32 pm
by Joe Schmoe
True.
And this is completely absurd. locate should be standard.
Pretty much the first thing I install on any new RPi image.
