martinrice
Finding a path
Fri Jun 28, 2013 10:09 am
How do I find the path to a file?
Thanks.
Pankoi
Re: Finding a path
Fri Jun 28, 2013 10:17 am
If you're in a terminal and in the same directory as the file, you can type 'pwd' to get the path to the current directory and then you should just be able to stick the filename on the end, if that's what you mean? :)
Hope that helps,
~Richard Williams
The Pi Store: the home of games, apps, tutorials and other content for Raspberry Pi - store.raspberrypi.com
Want to hear about new Pi Store content? Follow @PiStoreReleases on Twitter.
joan
Re: Finding a path
Fri Jun 28, 2013 10:19 am
If you know the filename try
find / -name "filename"
If you know only part of the filename try
find / -name "*filename*"
Re: Finding a path
Fri Jun 28, 2013 10:23 am
Also, try the whereis command.
RaTTuS
Contact: Twitter YouTube
Re: Finding a path
Fri Jun 28, 2013 10:31 am
also
which
i.e.
which ls
Covfefe
martinrice
Re: Finding a path
Fri Jun 28, 2013 12:40 pm
Thanks one and all for the help. It's appreciated!
dr_d_gee
Re: Finding a path
Fri Jun 28, 2013 1:18 pm
If locate is installed (can't remember whether it is or not in the default Raspbian image) then
locate filename
will work. It uses a database of files so can produce results very quickly. If the database is not up-to-date you may need to do
sudo updatedb
first.
RaTTuS
Re: Finding a path
Fri Jun 28, 2013 1:24 pm
locate is not included in the raspbian image but you can add it
Covfefe
Joe Schmoe
Re: Finding a path
Fri Jun 28, 2013 1:32 pm
True.
And this is completely absurd. locate should be standard.
Pretty much the first thing I install on any new RPi image.
