Raspberry only draws 0,025 amperes?
Posted: Thu Jun 20, 2013 10:50 pm
by cybtrash
I have a rasperry pi with a 2 ampere power adapter.
I measured the power consumption with a current measuring device.
Running at 700Mhz, it consumes 2,5W with 0,025A.
Running at 1000Mhz, it consumes 3W with 0,028A
How can this be? I thought the raspberry needs at least ~700mA, going up to 1+A when devices are attached?
Why does my measuring device only show that low number?
The measuring device is this one:
KD 302
http://www.reichelt.de/Energiemessgerae ... &OFFSET=16&
Re: Raspberry only draws 0,025 amperes?
Posted: Thu Jun 20, 2013 11:02 pm
by Joe Schmoe
Well, there seems to be something wrong with your math.
If it is drawing 2.5 W at 5v, that's 500 mA (= 0.5 A), right?
And that's about right. Basically, what I've heard is that the Pi itself takes about 500mA and the ethernet (on a model B) draws about 230 mA (when running full speed/full blast).
Posted: Thu Jun 20, 2013 11:59 pm
by mahjongg
the low current numbers are on the mains 240V AC side of the power supply, not on the low voltage side!
Posted: Fri Jun 21, 2013 1:02 am
by MongolSamurai
Remember: Wattage is equal to voltage times amperage. When you step down the voltage, the amperage must raise to provide the same power to a device. 2.5 watts at 5v is about 0.5A, but 2.5 watts at 240v is a much lower number: 2.5w / 240v = 0.0104A
Posted: Fri Jun 21, 2013 2:29 am
by Joe Schmoe
mahjongg wrote:the low current numbers are on the mains 240V AC side of the power supply, not on the low voltage side!
Well, yeah, that would explain it as well...
Posted: Fri Jun 21, 2013 6:12 am
by cybtrash
Thank you all for your answers, now I get it! :)
