()blivion wrote:
OP's complaints seem more political than technical, so this is mostly irrelevant to the topic. But if one was worrying about this because they wish they had more usable pins they could work with, the two flex cable connectors and the P5 header have a few extra. Also, demultiplexers, shift registers, and/or microcontrollers can expand pins many fold. 100+ pins isn't unreasonable like this, though expect a proportionate drop in speed.
BTW, having lots of power wires helps with current if you are powering the Pi through the header... as I am.
Actually some of each.....
There apparently are claimed technical reasons for the multiple grounds (but what about the reasoning for 3v3 & 5v more than one place....) but it's been my experience thus far and with the on board connector being male rather than female that to really use this expansion you need to jumper all 26 pins over to a breadboard anyway where you just end up having rails for this sort of thing. actually I've learned that a single common ground point is better in most cases as it avoids ground loops and other common (ok, bad pun...) problems! just figured I'd ask what the tradeoffs were in the design. Not really complaining more just why certain tradeoffs observed and wondering what lead to those. I understand grouping things into functional groups but when those groups are still on the same header and the same cable duplicating common functions between them just never made sense to me, that's all.
