teh_orph
Re: Simon's accelerated X development thread
Tue Oct 16, 2012 10:03 pm
atarian88 wrote:Simon, which steps would one take to build this code of yours? I sort of managed by throwing the source into a xf86-video-fbdev source directory and modifying the Makefile.am to add the new source files, but since you added that big cpp file I have no clue how to build this.
Some friendly pointers would be appreciated. I'm on Arch Linux ARM (armv6h) if that helps. I'm sorry if I'm missing something obvious, but I'm new to X.org development.
Sorry for the delay - I've been away.
You need some modifications to the Xorg source itself, so make sure you can build that too.
The cpp stuff is a PITA, since the original build system did not seem geared for it. Also, the compiler will not emit (useful) ARMv6 SIMD instructions, so I've had to go via an intermediate asm step. There's a makefile target for it in Makefile.in. You'll need clang installed. Just to clarify, we compile the cpp+inl with Clang to assembly, tack on an asm macro and then recompile the code with GCC using one of the inbuilt rules.
I'm developing the whole thing in Arch (the April distro) anyway, so should be able to guide you along.
atarian88
Thu Oct 18, 2012 10:54 am
OK, thanks for you reply. I am able to build the Xorg server, as I've downloaded the source before. I'm a complete newbie when it comes to clang as well. A set of patches against the xorg-server source would be nice, if applicable.
It's exciting that you're almost finished. What do you plan to do with regards to the official effort to bring EXA to the Pi?
teh_orph
Thu Oct 18, 2012 10:35 pm
Yeah I really need to compile some patches against X - the driver won't work as-is. You also need to compile the Linux kernel, if you haven't done already and download my dma module from github. Github is getting DDOS'd right now, so I don't have a link to hand!
Besides not being able to check in some new stuff, proper successful evening today.
- the X people have fixed the bug I found in the Xorg server https://bugs.freedesktop.org/show_bug.cgi?id=55723 and I can confirm it works...even a rare corruption bug I've been seeing in Midori for six months has gone away!
- I've finally gotten a handle on the AXI burst value that can freeze your Pi or turn off the screen(!), and also being able to use the AXI burst in addition to source/destination burst. That's a 5x increase in window dragging/upload/download performance...
- I've spent the last few days with a test kernel in VirtualBox messing around with 'reserved' memory. I really need this in order to get a piece of memory that's not chopped up into 4k pages. I wrote the code for the Pi this evening and have X running with it. This can theoretically give up to 3x increase in said dragging.
- since I'm now not (always) bound by 4k pages, I can use the 2D DMA operations! That will lower the CPU load and also greatly reduce the DMA start-up cost. Wup wup.
I just now need to do a tidy up on this 4k page stuff (which will probably take all weekend), implement a few more composite operations (easy), and also try and bump up the composite code gen performance by 20%. And...that's it??!
NB: this reserved memory stuff should work really well I think n the 512MB Pis.
portets
Fri Oct 19, 2012 2:45 am
Wow, exciting stuff. Is there any collaboration going on with this and http://www.raspberrypi.org/phpBB3/viewt ... 00#p194400 :?:
hojnikb
Fri Oct 19, 2012 8:33 am
This is really great to finally see X has come this far.
What would be the minimum mem. split for accelaration to work ?
Would be 16MBs be enough ?
+°´°+,¸¸,+°´°~ Everyone should have a taste of UK Raspberry Pie =D ~°´°+,¸¸,+°´°+
Rasberry Pi, SoC @ 1225Mhz :o, 256MB Ram @ 550Mhz, 16GB SD-Card, Raspbian
teh_orph
Fri Oct 19, 2012 8:55 am
hojnikb wrote:This is really great to finally see X has come this far.
Yep. This is what I'm actually targetting. And also in 32-bit colour mode; I've not put in much effort for 15/16-bit colour.
hojnikb
Fri Oct 19, 2012 10:06 pm
Thats great for us with 256MB boards :D
Lots of free ram and less arm usage is what what Pi really needs for desktop use.
teh_orph
Fri Oct 19, 2012 11:04 pm
If you could stick this at the end of config.txt
framebuffer_depth=32
framebuffer_ignore_alpha=1
and get used to 32-bit X for a bit that'll help me out! (makes a better impression ;))
lb
Fri Oct 19, 2012 11:25 pm
16 bit has horrible color banding, I'm glad the focus is on 24/32 bits. :)
teh_orph
Mon Oct 22, 2012 8:54 am
teh_orph wrote:I just now need to do a tidy up on this 4k page stuff (which will probably take all weekend), implement a few more composite operations (easy), and also try and bump up the composite code gen performance by 20%. And...that's it??!
All done!
There's still lots of stuff that I'd like to do to handle large composition ops (which are still too slow) but that'll be another month or two of work. The stuff that EXA appears geared for - window dragging and scrolling, font rendering - are now where I'd like them.
Code's going to testers now.
dliloch
Mon Oct 22, 2012 9:40 am
this is fantastic.. how does one become a "tester" ?? I would like to try it ...
hojnikb
Mon Oct 22, 2012 1:48 pm
Yeah, i would like to test awell :)
Hexxeh
Mon Oct 22, 2012 1:51 pm
+1, especially if there's some EGL goodness!
hojnikb
Mon Oct 22, 2012 1:58 pm
hmmm what about color issues with 24/32bit, is that fixed or is it still present ?
(looking at the wiki, haven't tried myself)
teh_orph
Mon Oct 22, 2012 2:59 pm
I'm afraid there is not an ounce of EGL in this code. There are some key things I'm planning on doing for the next version, which I'd imagine would be good to go in a number of months. I figured that if I just kept adding to the code, I'd never get anything out!
Now that I have full control over the graphics library I can choose to CPU+DMA some things and GPU some other things. The commands sent by applications need to have a low latency and if I'd done all the work with the GPU then it'd probably be slower than the stock X.
When I write this code (which is what I'm doing next) EGL interop should be much easier.
hojnikb wrote:hmmm what about color issues with 24/32bit, is that fixed or is it still present ?
Which issue in particular? Just bust in the config.txt settings that enable 32-bit and you're good to go! As long as your binary blob is recent-ish.
ghans
Mon Oct 22, 2012 5:02 pm
Just a little question : Do you know anything about the engineering
resource the foundation has put on X acceleration ? Perhaps it would be better if you
worked together ?
ghans
factoid
Mon Oct 22, 2012 5:39 pm
I emailed them regarding my project, since I wondered if it was worth continuing my approach, didn't discuss Simon's stuff, but I haven't heard back either way. Hopefully we can all benefit from each other's work in the end, though I'm still playing catch up.
masterluke
Wed Oct 24, 2012 10:01 am
Any word on how the testing is going? Would LOVE to see this in action.
Thanks for all your hard work
cave
Wed Oct 24, 2012 12:14 pm
UPDATE
http://www.raspberrypi.org/archives/2221
Liz wrote:We've (with Broadcom's help) open sourced the ARM userland. More at http://www.raspberrypi.org/archives/2221 - hurrah!
Asb wrote: It’s not going to have an immediate impact on X acceleration, though as I say does make it possible to provide the necessary Wayland EGL support for hardware compositing. There’s still the problem of optimising client-side rendering of each window. Simon Hall has done some interesting work on XOrg that we’re working with him to package up.
http://cavebeat.blogspot.co.at
cave
Thu Oct 25, 2012 6:29 am
Hi
I have found this:
VideoCore IV Programmers Manual
https://github.com/hermanhermitage/vide ... ers-Manual
Disclaimer:
This is a independent documentation project based on a combination of static analysis and trial and error on
real hardware. This work is 100% independent from and not sanctioned by or connected with Broadcom or its agents.
No Broadcom documents or materials were used beyond those publically available.
This work was undertaken and the information provided for non commercial use on the expectation that hobbyists of
all ages will find the details useful for understanding and working with their Raspberry Pi hardware.
The hope is that Broadcom will be flattered by the interest in the device and understand the benefits of opening up
understanding to a larger audience of potential customers and developers.
Broadcom should be commended with making their SoC available for a project as exciting as the Raspberry Pi.
No copyrighted materials are contained in this repository.
teh_orph
Thu Oct 25, 2012 9:34 am
Although this does not help me with the Xorg driver project, it should make it pretty easy for me to write an EGL thingy for Hexxeh (but I don't think it would have been too tricky in the first place...famous last words!)
Hexxeh
Thu Oct 25, 2012 9:36 am
teh_orph wrote:Although this does not help me with the Xorg driver project, it should make it pretty easy for me to write an EGL thingy for Hexxeh (but I don't think it would have been too tricky in the first place...famous last words!)
"pretty easy"
I'm liking the sound of this. I can smell the Chromium OS images cooking already..!
teh_orph
Thu Oct 25, 2012 10:17 am
So just to clarify, do you want existing EGL code that expects to render into an X window "to just work"?
Not a full-screen EGL application that runs sans-X (like Android)?
Hexxeh
Thu Oct 25, 2012 10:23 am
teh_orph wrote:So just to clarify, do you want existing EGL code that expects to render into an X window "to just work"?
Yeah, you can test by passing --use_gl=egl to Chromium if I remember rightly.
teh_orph
Thu Oct 25, 2012 11:11 am
Like Chromium that works in Raspbian?
I have noticed that Chromium (and Iceweasel) are dog slow on Rpi. Netsurf is super fast on my machine! (I don't overclock)
