Jeffreytooker
Re: Linux Distros ARM
Sat Apr 07, 2012 7:25 pm
MMCC:
Nice explanation of difference between X86 and ARM CPU's.  It tells me a lot.  Does this then mean that most of the downloadable packages in common use will not run on RPi?  If so this would mean a loss of support found in most other Linux based systems.  It also seems that unless one knows specifically by name which distros are ARM, one can not tell ARM from X86. by  the Kernel designation.
It seems to me that ARM is still Linux but completely different from most other Linux distros.  It is like the difference between Asian and African elephants.
Jeffrey
Jessie
Sat Apr 07, 2012 8:05 pm
Jeffreytooker said:
MMCC:
No most common packages have been recompiled and tested for ARM.  When you use the Package manager on your choice of distro it will pull the ARM version.  If no ARM version is avalible then it will tell you that the package does not exist, this at least is my exp using Archlinux ARM.
Most Linux users are not like most Windows users.  They know the diference between ARM and x86.  This may change with such inexpensive devices like the R-Pi, but as it stands right now I seriously doubt that most Linux users will be confused why an x86 distro won't work or install on an ARM Based machine.  Furthermore the case you are making right now dosn't even make much sense.  Most distros out there are compiled to run on SPARC, PPC, MIPS and many other processors for many years and it hasn't caused any confusion that I have seen.
Jeffrey
ARM is not Linux.  Linux is software.  ARM is RISC hardware.  After setup the OS dosn't behave any differently on an x86 based system than an ARM system (other than the performance differences.)  Config files are in the same places, Samba acts like Samba, miniDLNA acts like miniDLNA regaurdless of hardware.  The CLI commands work the same.
The difference here is just that the binarys have to be compiled for ARM and be Linux binaries, x86 binaries will not work.  Software that is low level coded for x86 processors will not work without major re-writes.  Most of the common software has already been rewritten for ARM.  You can go through Debian's, Arch's, or Fedora's  Pacage repos to see what they officially support.  By all means this dosn't mean that just because a package isn't there that it won't work just that anything outside of the repo will either have to be community supported or user compiled.  Here is Arch's package list. http://archlinuxarm.org/packages
I list Arch's website because that I what I use, I find their community the best and thier distro easiest to implement.  Everyone has their own opinions on what they like.  At any rate you can go through that package list and see that some are listed arm v5 and arm v7.  The processor in the R-Pi is an arm v6 based processor.  Anything listed arm v5 will run on it, stuff listed as arm v7 only may or may not.  Going through their repo I see Gimp, various desktop front-ends, Samba, miniDLNA, word processors, internet browsers, ect all the basics.
For the basic user all they will need to know is that they update the package manager and then get the package they want.  The manager won't grab an incompatible package (as far as I have seen.)  I have a different ARM based machine and I have yet to have it pull an un-useable package (aside from experemental in-development stuff.)  I would also venture to say that most of the distros will come pre-configured with all the common software for the user.  It will be a matter of formatting the SD card and ploping the image onto it.  Again here is Arch's installation instructions for the R-Pi:  http://archlinuxarm.org/platfo.....spberry-pi click on the installation tab.  It is dead simple, and pretty much the same for whatever distro you download for the R-Pi.
SN
Sat Apr 07, 2012 8:18 pm
Think of it in these terms. Consider the cpus as car engines and the distros/software as fuel. You put petrol in a diesl engine it won"t work. The same is true for x86 software binaries and an ARM cpu
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
bredman
Sat Apr 07, 2012 8:58 pm
The difference between ARM and x86 would seem to be important to somebody who comes from a Windows background. All the way from DOS to Windows 7, programs have always worked on x86 hardware and nothing else, the user never had to worry about it.
For Unix and Linux, the story is completely different. Unix and Linux have been used on dozens of different hardware types over the last 30+ years. This means that the developers have had to be careful to make the software transferrable to different hardware. It also means that the package management software is intelligent enough to find the correct package versions to suit the hardware.
For you, the end user, this means that the choice of hardware is not really important. If you use popular hardware such as ARM, you can assume that at least the top 1000 packages will be available to you when you need them. I have used ARM5 for the last 6 years and really pushed the package installer to the limit, but I have never noticed a missing package when I needed it.
AlArenal
Sat Apr 07, 2012 10:09 pm
That's not entirely true. In times of Windows NT there was also a version for DEC Alpha and MIPS CPUs, although the average Joe never noticed.
SN
Sat Apr 07, 2012 10:30 pm
Alex Langer said:
In times of Windows NT there was also a version for DEC Alpha.
There was indeed - for a short while I worked in one of the DEC offices in the USA where NT for Alpha was worked on
Kernel
Sun Apr 08, 2012 2:39 pm
As mentioned most packages are available for ARM and once people have the raspi's themselves I expect more will be ported.
There may be some issues compiling programs without binaries if the makefile etc. is for x86 specifically - but hopefully developers will see the need for compatibility with ARM once the raspi gets a lot of users.
