Re: Where is the Bottleneck?
Mine is NTFS-formatted, would ext4 be a noticeable improvement and is it compatible with Windows and Android? I usually access the raspberry pi device containing the NTFS hdd through win and android. It's also using Samba, perhaps NFS would be better?
ext4 will at least double the transfer rate - ext4 disks
don't work if directly connected to a Windows PC.
But if you are using Samba , it should make no difference in
compatibility.
ghans
compatibility.
ghans
I see, so if I format it in to ext4 I wont be able to connect to the drive directly from Windows. But connecting to it through samba is fine. What about NFS then? Currently, samba uses about 40% cpu when I'm transferring files to the drive, and when doing some minor research I see that NFS is a lot better in the regard of cpu usage. It could even drop down 10 times, to about 4%. Wouldn't that be a smart move? Or there's compatibility issues with accessing it from a Windows machine? I also read somewhere that Windows has had a problem with NFS since the start of it all, back in the 80s but they recently added some kind of support for Windows 7 if I'm not mistaken.
- RaTTuS
- Contact: Twitter YouTube
ext4 on linux is loads better than ntfs
Covfefe
Covfefe
NFS for Windows is only included in the Pro versions AFAIK.
I guess you're stuck with Samba.
ghans
ghans
Actually I have Windows 8.1 Pro but the service doesn't exist there. Perhaps I should get the Enterprise edition as it exist there. Do you think NFS would be an improvement? If so, I'll re-install with Enterprise.
- Raspberry Pi Engineer & Forum Moderator
I use hanewin nfs server on Windows:ech0 wrote:Actually I have Windows 8.1 Pro but the service doesn't exist there. Perhaps I should get the Enterprise edition as it exist there. Do you think NFS would be an improvement? If so, I'll re-install with Enterprise.
http://www.hanewin.net/nfs-e.htm
You do pay for it, but you can try it free for a month to see if it works for you.
I guess he needs a NFS client ...
ghans
ghans
Just to others with the same problem, I've tested SMB and NFS, with NTFS and EXT4.
I use a clean image of Raspbian, with a External HD 3.5 and auto-powered.
The results is:
SMB + NTFS = less than 2MB (~700KB)
SMB + EXT4 = up to 2MB
NFS + NTFS = up to 2MB
NFS + EXT4 = up to 8MB (Mac OS ~8MB and Windows 6MB).
I hope this help someone.
The results is:
I have EXT4 formatted HDDs on all RPis and get always about 11.5 MB/sec with all Samba transfers.
Minimal Kiosk Browser (kweb)
