ech0
Re: Where is the Bottleneck?
Tue Feb 11, 2014 10:24 pm
Mine is NTFS-formatted, would ext4 be a noticeable improvement and is it compatible with Windows and Android? I usually access the raspberry pi device containing the NTFS hdd through win and android. It's also using Samba, perhaps NFS would be better?
ghans
Wed Feb 12, 2014 6:01 am
ext4 will at least double the transfer rate - ext4 disks
don't work if directly connected to a Windows PC.
But if you are using Samba , it should make no difference in
compatibility.
ghans
ech0
Wed Feb 12, 2014 11:48 am
I see, so if I format it in to ext4 I wont be able to connect to the drive directly from Windows. But connecting to it through samba is fine. What about NFS then? Currently, samba uses about 40% cpu when I'm transferring files to the drive, and when doing some minor research I see that NFS is a lot better in the regard of cpu usage. It could even drop down 10 times, to about 4%. Wouldn't that be a smart move? Or there's compatibility issues with accessing it from a Windows machine? I also read somewhere that Windows has had a problem with NFS since the start of it all, back in the 80s but they recently added some kind of support for Windows 7 if I'm not mistaken.
RaTTuS
Contact: Twitter YouTube
Wed Feb 12, 2014 11:50 am
ext4 on linux is loads better than ntfs
Covfefe
ghans
Wed Feb 12, 2014 4:18 pm
NFS for Windows is only included in the Pro versions AFAIK.
I guess you're stuck with Samba.
ghans
ech0
Wed Feb 12, 2014 6:37 pm
Actually I have Windows 8.1 Pro but the service doesn't exist there. Perhaps I should get the Enterprise edition as it exist there. Do you think NFS would be an improvement? If so, I'll re-install with Enterprise.
dom
Wed Feb 12, 2014 10:23 pm
ech0 wrote:Actually I have Windows 8.1 Pro but the service doesn't exist there. Perhaps I should get the Enterprise edition as it exist there. Do you think NFS would be an improvement? If so, I'll re-install with Enterprise.
I use hanewin nfs server on Windows:
http://www.hanewin.net/nfs-e.htm
You do pay for it, but you can try it free for a month to see if it works for you.
ghans
Thu Feb 13, 2014 7:52 am
I guess he needs a NFS client ...
ghans
sendtojoao
Mon Feb 13, 2017 9:06 pm
Just to others with the same problem, I've tested SMB and NFS, with NTFS and EXT4.
I use a clean image of Raspbian, with a External HD 3.5 and auto-powered.
The results is:
SMB + NTFS = less than 2MB (~700KB)
SMB + EXT4 = up to 2MB
NFS + NTFS = up to 2MB
NFS + EXT4 = up to 8MB (Mac OS ~8MB and Windows 6MB).
I hope this help someone.
gkreidl
Mon Feb 13, 2017 9:59 pm
I have EXT4 formatted HDDs on all RPis and get always about 11.5 MB/sec with all Samba transfers.
Minimal Kiosk Browser (kweb)
