xnosek00
filesystem corruption - unstable raspberry
Wed May 29, 2013 7:59 pm
I don't know why, but Raspi is totaly unstable for me. I'm angry, because after installing new package - my SD card is totally corrupted. The system files are totaly damaged. I have to clean SD card and install raspbian distribution again. It is not first time.
Hardware:
recommended SD card - Sandisk class 4, 8 GB.
raspi 512 RAM
usb hub - self powered
usb disk - self powered
tv card - in self powered hub
overlocked - 950 MHz
I tried to connect GSM dongle and install asterisk. I enclose my dmesg during the instalation asterisk. When I saw erorrs in dmesg, I tried reboot raspi. Data are completely damaged and filesystem is not bootable.
There is no problem with power supply. I tried it before by multimeter. From time to time, I had some data corruption on sd card. But now is completely damaged. Maybe it was matter of time.
I have several Raspi. There is data corruption on all sd cards from time to time. I can't rely on Raspberry. My raspberry is powered all the time.
Does anybody have the same problem of data corruption? How is it possible??
xnosek00
Re: filesystem corruption - unstable raspberry
Wed May 29, 2013 8:03 pm
[  253.013185] hub 1-1.2:1.0: unable to enumerate USB device on port 2
[  454.215794] usb 1-1.2.1: new high-speed USB device number 11 using dwc_otg
[  454.317860] usb 1-1.2.1: New USB device found, idVendor=12d1, idProduct=1520
[  454.317907] usb 1-1.2.1: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[  454.317926] usb 1-1.2.1: Product: HUAWEI Mobile
[  454.317941] usb 1-1.2.1: Manufacturer: HUAWEI Technology
[  454.333323] scsi1 : usb-storage 1-1.2.1:1.0
[  455.327229] scsi 1:0:0:0: CD-ROM            Vodafone CD ROM (Huawei)  2.31 PQ: 0 ANSI: 2
[  455.369063] sr0: scsi-1 drive
[  455.369093] cdrom: Uniform CD-ROM driver Revision: 3.20
[  455.373212] sr 1:0:0:0: Attached scsi CD-ROM sr0
[  516.396669] usb 1-1.2.1: reset high-speed USB device number 11 using dwc_otg
[  802.111483] mmc0: Controller never released inhibit bit(s).
[  802.115623] mmcblk0: timed out sending r/w cmd command, card status 0x400d00
[  834.400495] mmc0: Timeout waiting for hardware interrupt - cmd25.
[  834.400552] mmc0: resetting ongoing cmd 25DMA before 4096/4096 [7]/[11] complete
[  834.403397] mmcblk0: error -110 transferring data, sector 391040, nr 88, cmd response 0x900, card status 0x0
[  834.404616] end_request: I/O error, dev mmcblk0, sector 391089
[  834.404646] end_request: I/O error, dev mmcblk0, sector 391096
[  834.404678] end_request: I/O error, dev mmcblk0, sector 391104
[  834.404694] end_request: I/O error, dev mmcblk0, sector 391112
[  834.404707] end_request: I/O error, dev mmcblk0, sector 391120
[  834.404730] Buffer I/O error on device mmcblk0p2, logical block 33520
[  834.404771] Buffer I/O error on device mmcblk0p2, logical block 33521
[  834.404802] Buffer I/O error on device mmcblk0p2, logical block 33522
[  834.404819] Buffer I/O error on device mmcblk0p2, logical block 33523
[  834.404832] Buffer I/O error on device mmcblk0p2, logical block 33524
[  834.404845] Buffer I/O error on device mmcblk0p2, logical block 33525
[  834.404858] Buffer I/O error on device mmcblk0p2, logical block 33526
[  834.404871] Buffer I/O error on device mmcblk0p2, logical block 33527
[  834.404883] Buffer I/O error on device mmcblk0p2, logical block 33528
[  834.404908] Buffer I/O error on device mmcblk0p2, logical block 33529
[  834.404924] Buffer I/O error on device mmcblk0p2, logical block 33530
[  834.404946] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:250: I/O error writing to inode 44 (offset 0 size 45056 starting block 48891)
[  834.405149] JBD2: Detected IO errors while flushing file data on mmcblk0p2-8
[  834.913050] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:741: group 48, 17259 clusters in bitmap, 19065 in gd
[  834.929123] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[  834.951729] mmc0: Controller never released inhibit bit(s).
[  834.953004] mmcblk0: unknown error -5 sending read/write command, card status 0xb00
[  834.953033] end_request: I/O error, dev mmcblk0, sector 3792896
[  834.953102] EXT4-fs error (device mmcblk0p2): ext4_wait_block_bitmap:445: comm aptitude: Cannot read block bitmap - block_group = 14, block_bitmap = 458752
[  845.000543] mmc0: Timeout waiting for hardware interrupt - cmd25.
[  845.000585] mmc0: resetting ongoing cmd 25DMA before 4096/4096 [4]/[19] complete
[  845.002850] mmcblk0: error -110 transferring data, sector 9075688, nr 1024, cmd response 0x900, card status 0x0
[  845.003076] end_request: I/O error, dev mmcblk0, sector 9075779
[  845.003125] end_request: I/O error, dev mmcblk0, sector 9075784
[  845.003151] end_request: I/O error, dev mmcblk0, sector 9075792
[  845.003175] end_request: I/O error, dev mmcblk0, sector 9075800
[  845.003198] end_request: I/O error, dev mmcblk0, sector 9075808
[  845.003232] end_request: I/O error, dev mmcblk0, sector 9075816
[  845.003257] end_request: I/O error, dev mmcblk0, sector 9075824
[  845.003280] end_request: I/O error, dev mmcblk0, sector 9075832
[  845.003302] end_request: I/O error, dev mmcblk0, sector 9075840
[  845.003324] end_request: I/O error, dev mmcblk0, sector 9075848
[  845.003984] Buffer I/O error on device mmcblk0p2, logical block 1119101
[  845.004013] Buffer I/O error on device mmcblk0p2, logical block 1119102
[  845.004029] Buffer I/O error on device mmcblk0p2, logical block 1119103
[  845.004042] Buffer I/O error on device mmcblk0p2, logical block 1119104
[  845.004057] Buffer I/O error on device mmcblk0p2, logical block 1119105
[  845.004069] Buffer I/O error on device mmcblk0p2, logical block 1119106
[  845.004083] Buffer I/O error on device mmcblk0p2, logical block 1119107
[  845.004110] Buffer I/O error on device mmcblk0p2, logical block 1119108
[  845.004125] Buffer I/O error on device mmcblk0p2, logical block 1119109
[  845.004139] Buffer I/O error on device mmcblk0p2, logical block 1119110
[  845.004152] Buffer I/O error on device mmcblk0p2, logical block 1119111
[  845.004165] Buffer I/O error on device mmcblk0p2, logical block 1119112
[  845.004178] Buffer I/O error on device mmcblk0p2, logical block 1119113
[  845.004192] Buffer I/O error on device mmcblk0p2, logical block 1119114
[  845.004204] Buffer I/O error on device mmcblk0p2, logical block 1119115
[  845.004230] Buffer I/O error on device mmcblk0p2, logical block 1119116
[  845.004244] Buffer I/O error on device mmcblk0p2, logical block 1119117
[  845.004259] Buffer I/O error on device mmcblk0p2, logical block 1119118
[  845.004272] Buffer I/O error on device mmcblk0p2, logical block 1119119
[  845.004284] Buffer I/O error on device mmcblk0p2, logical block 1119120
[  845.004297] Buffer I/O error on device mmcblk0p2, logical block 1119121
[  845.004310] Buffer I/O error on device mmcblk0p2, logical block 1119122
[  845.004322] Buffer I/O error on device mmcblk0p2, logical block 1119123
[  845.004336] Buffer I/O error on device mmcblk0p2, logical block 1119124
[  845.004358] Buffer I/O error on device mmcblk0p2, logical block 1119125
[  845.004375] Buffer I/O error on device mmcblk0p2, logical block 1119126
[  845.004390] Buffer I/O error on device mmcblk0p2, logical block 1119127
[  845.004404] Buffer I/O error on device mmcblk0p2, logical block 1119128
[  845.004417] Buffer I/O error on device mmcblk0p2, logical block 1119129
[  845.004430] Buffer I/O error on device mmcblk0p2, logical block 1119130
[  845.004443] Buffer I/O error on device mmcblk0p2, logical block 1119131
[  845.004456] Buffer I/O error on device mmcblk0p2, logical block 1119132
[  845.004480] Buffer I/O error on device mmcblk0p2, logical block 1119133
[  845.004495] Buffer I/O error on device mmcblk0p2, logical block 1119134
[  845.004509] Buffer I/O error on device mmcblk0p2, logical block 1119135
[  845.004523] Buffer I/O error on device mmcblk0p2, logical block 1119136
[  845.004535] Buffer I/O error on device mmcblk0p2, logical block 1119137
[  845.004548] Buffer I/O error on device mmcblk0p2, logical block 1119138
[  845.004561] Buffer I/O error on device mmcblk0p2, logical block 1119139
[  845.004574] Buffer I/O error on device mmcblk0p2, logical block 1119140
[  845.004597] Buffer I/O error on device mmcblk0p2, logical block 1119141
[  845.004612] Buffer I/O error on device mmcblk0p2, logical block 1119142
[  845.004626] Buffer I/O error on device mmcblk0p2, logical block 1119143
[  845.004640] Buffer I/O error on device mmcblk0p2, logical block 1119144
[  845.004653] Buffer I/O error on device mmcblk0p2, logical block 1119145
[  845.004666] Buffer I/O error on device mmcblk0p2, logical block 1119146
[  845.004679] Buffer I/O error on device mmcblk0p2, logical block 1119147
[  845.004692] Buffer I/O error on device mmcblk0p2, logical block 1119148
[  845.004705] Buffer I/O error on device mmcblk0p2, logical block 1119149
[  845.004745] Buffer I/O error on device mmcblk0p2, logical block 1119150
[  845.004762] Buffer I/O error on device mmcblk0p2, logical block 1119151
[  845.004776] Buffer I/O error on device mmcblk0p2, logical block 1119152
[  845.004789] Buffer I/O error on device mmcblk0p2, logical block 1119153
[  845.004802] Buffer I/O error on device mmcblk0p2, logical block 1119154
[  845.004814] Buffer I/O error on device mmcblk0p2, logical block 1119155
[  845.004827] Buffer I/O error on device mmcblk0p2, logical block 1119156
[  845.004863] Buffer I/O error on device mmcblk0p2, logical block 1119157
[  845.004880] Buffer I/O error on device mmcblk0p2, logical block 1119158
[  845.004895] Buffer I/O error on device mmcblk0p2, logical block 1119159
[  845.004908] Buffer I/O error on device mmcblk0p2, logical block 1119160
[  845.004921] Buffer I/O error on device mmcblk0p2, logical block 1119161
[  845.005138] Buffer I/O error on device mmcblk0p2, logical block 1119162
[  845.005159] Buffer I/O error on device mmcblk0p2, logical block 1119163
[  845.005173] Buffer I/O error on device mmcblk0p2, logical block 1119164
[  845.005187] Buffer I/O error on device mmcblk0p2, logical block 1119165
[  845.005201] Buffer I/O error on device mmcblk0p2, logical block 1119166
[  845.005229] Buffer I/O error on device mmcblk0p2, logical block 1119167
[  845.005722] Buffer I/O error on device mmcblk0p2, logical block 1119201
[  845.005738] Buffer I/O error on device mmcblk0p2, logical block 1119202
[  845.005752] Buffer I/O error on device mmcblk0p2, logical block 1119203
[  845.005765] Buffer I/O error on device mmcblk0p2, logical block 1119204
[  845.005778] Buffer I/O error on device mmcblk0p2, logical block 1119205
[  845.005791] Buffer I/O error on device mmcblk0p2, logical block 1119206
[  845.005804] Buffer I/O error on device mmcblk0p2, logical block 1119207
[  845.005816] Buffer I/O error on device mmcblk0p2, logical block 1119208
[  845.005829] Buffer I/O error on device mmcblk0p2, logical block 1119209
[  845.005853] Buffer I/O error on device mmcblk0p2, logical block 1119210
[  845.005867] Buffer I/O error on device mmcblk0p2, logical block 1119211
[  845.005881] Buffer I/O error on device mmcblk0p2, logical block 1119212
[  845.005893] Buffer I/O error on device mmcblk0p2, logical block 1119213
[  845.005907] Buffer I/O error on device mmcblk0p2, logical block 1119214
[  845.005920] Buffer I/O error on device mmcblk0p2, logical block 1119215
[  845.005932] Buffer I/O error on device mmcblk0p2, logical block 1119216
[  845.005945] Buffer I/O error on device mmcblk0p2, logical block 1119217
[  845.005957] Buffer I/O error on device mmcblk0p2, logical block 1119218
[  845.005981] Buffer I/O error on device mmcblk0p2, logical block 1119219
[  845.005996] Buffer I/O error on device mmcblk0p2, logical block 1119220
[  845.006009] Buffer I/O error on device mmcblk0p2, logical block 1119221
[  845.006035] Buffer I/O error on device mmcblk0p2, logical block 1119222
[  845.006049] Buffer I/O error on device mmcblk0p2, logical block 1119223
[  845.006062] Buffer I/O error on device mmcblk0p2, logical block 1119224
[  845.006075] Buffer I/O error on device mmcblk0p2, logical block 1119225
[  845.006101] Buffer I/O error on device mmcblk0p2, logical block 1119226
[  845.006117] Buffer I/O error on device mmcblk0p2, logical block 1119227
[  845.006132] Buffer I/O error on device mmcblk0p2, logical block 1119228
[  845.006154] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:250: I/O error writing to inode 237 (offset 0 size 524288 starting block 1134589)
[  846.047311] mmc0: Controller never released inhibit bit(s).
[  846.055610] mmcblk0: unknown error -5 sending read/write command, card status 0xb00
[  846.055680] Buffer I/O error on device mmcblk0p2, logical block 9072
[  846.055708] Buffer I/O error on device mmcblk0p2, logical block 9073
[  846.055734] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:250: I/O error writing to inode 1409 (offset 81920 size 8192 starting block 24434)
[  848.278329] JBD2: Detected IO errors while flushing file data on mmcblk0p2-8
[  849.268704] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586487:freeing already freed block (bit 13623)
[  849.285415] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586488:freeing already freed block (bit 13624)
[  849.301381] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586489:freeing already freed block (bit 13625)
[  849.317029] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586490:freeing already freed block (bit 13626)
[  849.332840] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586491:freeing already freed block (bit 13627)
[  849.348641] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586492:freeing already freed block (bit 13628)
[  849.364573] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586493:freeing already freed block (bit 13629)
[  849.381174] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586494:freeing already freed block (bit 13630)
[  849.397505] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586495:freeing already freed block (bit 13631)
[  849.413893] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586496:freeing already freed block (bit 13632)
[  849.430258] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586497:freeing already freed block (bit 13633)
[  849.446715] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586498:freeing already freed block (bit 13634)
[  849.463103] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586499:freeing already freed block (bit 13635)
[  849.479506] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586500:freeing already freed block (bit 13636)
[  849.495878] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586501:freeing already freed block (bit 13637)
[  849.512166] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586502:freeing already freed block (bit 13638)
[  849.528627] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586503:freeing already freed block (bit 13639)
[  849.544881] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586504:freeing already freed block (bit 13640)
[  849.561253] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586505:freeing already freed block (bit 13641)
[  849.577442] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586506:freeing already freed block (bit 13642)
[  849.593872] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586507:freeing already freed block (bit 13643)
[  849.610202] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586508:freeing already freed block (bit 13644)
[  849.626403] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586509:freeing already freed block (bit 13645)
[  849.642780] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586510:freeing already freed block (bit 13646)
[  849.659212] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586511:freeing already freed block (bit 13647)
[  849.675429] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586512:freeing already freed block (bit 13648)
[  849.691772] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586513:freeing already freed block (bit 13649)
[  849.708178] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586514:freeing already freed block (bit 13650)
[  849.724585] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586515:freeing already freed block (bit 13651)
[  849.740957] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586516:freeing already freed block (bit 13652)
[  849.757348] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586517:freeing already freed block (bit 13653)
[  849.773761] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586518:freeing already freed block (bit 13654)
[  849.790071] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586519:freeing already freed block (bit 13655)
[  849.806520] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586520:freeing already freed block (bit 13656)
[  849.822911] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586521:freeing already freed block (bit 13657)
[  849.839176] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586522:freeing already freed block (bit 13658)
[  849.855645] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586523:freeing already freed block (bit 13659)
[  849.872058] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586524:freeing already freed block (bit 13660)
[  849.888412] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586525:freeing already freed block (bit 13661)
[  849.904820] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586526:freeing already freed block (bit 13662)
[  849.921231] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586527:freeing already freed block (bit 13663)
[  849.937559] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586528:freeing already freed block (bit 13664)
[  849.954084] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586529:freeing already freed block (bit 13665)
[  849.970455] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586530:freeing already freed block (bit 13666)
[  849.986854] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586531:freeing already freed block (bit 13667)
[  850.003242] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586532:freeing already freed block (bit 13668)
[  850.019687] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586533:freeing already freed block (bit 13669)
[  850.036072] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586534:freeing already freed block (bit 13670)
[  850.052429] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586535:freeing already freed block (bit 13671)
[  850.068805] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586536:freeing already freed block (bit 13672)
[  850.085201] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586537:freeing already freed block (bit 13673)
[  850.101589] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586538:freeing already freed block (bit 13674)
[  850.117943] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586539:freeing already freed block (bit 13675)
[  850.134332] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586540:freeing already freed block (bit 13676)
[  850.150670] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586541:freeing already freed block (bit 13677)
[  850.166999] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586542:freeing already freed block (bit 13678)
[  850.183407] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586543:freeing already freed block (bit 13679)
[  850.199782] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586544:freeing already freed block (bit 13680)
[  850.216141] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586545:freeing already freed block (bit 13681)
[  850.232496] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586546:freeing already freed block (bit 13682)
[  850.248886] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586547:freeing already freed block (bit 13683)
[  850.265274] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586548:freeing already freed block (bit 13684)
[  850.281626] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586549:freeing already freed block (bit 13685)
[  850.298009] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586550:freeing already freed block (bit 13686)
[  850.314383] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586551:freeing already freed block (bit 13687)
[  850.330816] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586552:freeing already freed block (bit 13688)
[  850.347135] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586553:freeing already freed block (bit 13689)
[  850.363480] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586554:freeing already freed block (bit 13690)
[  850.379778] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586555:freeing already freed block (bit 13691)
[  850.396144] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586556:freeing already freed block (bit 13692)
[  850.412516] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586557:freeing already freed block (bit 13693)
[  850.428848] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586558:freeing already freed block (bit 13694)
[  850.445224] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586559:freeing already freed block (bit 13695)
[  850.461568] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586560:freeing already freed block (bit 13696)
[  850.477871] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586561:freeing already freed block (bit 13697)
[  850.494234] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586562:freeing already freed block (bit 13698)
[  850.510522] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586563:freeing already freed block (bit 13699)
[  850.526842] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586564:freeing already freed block (bit 13700)
[  850.543244] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586565:freeing already freed block (bit 13701)
[  850.559560] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586566:freeing already freed block (bit 13702)
[  850.575973] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586567:freeing already freed block (bit 13703)
[  850.592307] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586568:freeing already freed block (bit 13704)
[  850.608646] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586569:freeing already freed block (bit 13705)
[  850.624886] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586570:freeing already freed block (bit 13706)
[  850.641231] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586571:freeing already freed block (bit 13707)
[  850.657453] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586572:freeing already freed block (bit 13708)
[  850.673664] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586573:freeing already freed block (bit 13709)
[  850.689837] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586574:freeing already freed block (bit 13710)
[  850.706264] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586575:freeing already freed block (bit 13711)
[  850.722457] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586576:freeing already freed block (bit 13712)
[  850.738872] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586577:freeing already freed block (bit 13713)
[  850.755319] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586578:freeing already freed block (bit 13714)
[  850.771684] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586579:freeing already freed block (bit 13715)
[  850.788021] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586580:freeing already freed block (bit 13716)
[  850.804412] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586581:freeing already freed block (bit 13717)
[  850.820779] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586582:freeing already freed block (bit 13718)
[  854.836645] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586858:freeing already freed block (bit 13994)
[  854.852880] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586859:freeing already freed block (bit 13995)
[  854.869098] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586860:freeing already freed block (bit 13996)
[  854.885371] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586861:freeing already freed block (bit 13997)
[  854.901606] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586862:freeing already freed block (bit 13998)
[  854.917705] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586863:freeing already freed block (bit 13999)
[  854.934025] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586864:freeing already freed block (bit 14000)
[  854.950125] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586865:freeing already freed block (bit 14001)
[  854.966254] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586866:freeing already freed block (bit 14002)
[  854.982444] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586867:freeing already freed block (bit 14003)
[  854.998686] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586868:freeing already freed block (bit 14004)
[  855.014927] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586869:freeing already freed block (bit 14005)
[  855.031148] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586870:freeing already freed block (bit 14006)
[  855.047319] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586871:freeing already freed block (bit 14007)
[  855.063533] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586872:freeing already freed block (bit 14008)
[  855.079756] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586873:freeing already freed block (bit 14009)
[  855.095960] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586874:freeing already freed block (bit 14010)
[  855.112175] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586875:freeing already freed block (bit 14011)
[  855.128345] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586876:freeing already freed block (bit 14012)
[  855.144487] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586877:freeing already freed block (bit 14013)
[  855.160571] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586878:freeing already freed block (bit 14014)
[  855.176815] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586879:freeing already freed block (bit 14015)
[  855.193067] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586880:freeing already freed block (bit 14016)
[  855.209423] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586881:freeing already freed block (bit 14017)
[  855.225667] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586882:freeing already freed block (bit 14018)
[  855.241898] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586883:freeing already freed block (bit 14019)
[  855.258094] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586884:freeing already freed block (bit 14020)
[  855.274468] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586885:freeing already freed block (bit 14021)
[  855.290589] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586886:freeing already freed block (bit 14022)
[  855.306850] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586887:freeing already freed block (bit 14023)
[  855.323008] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586888:freeing already freed block (bit 14024)
[  855.339238] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586889:freeing already freed block (bit 14025)
[  855.355537] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586890:freeing already freed block (bit 14026)
[  855.371840] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586891:freeing already freed block (bit 14027)
[  855.388098] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586892:freeing already freed block (bit 14028)
[  855.404333] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586893:freeing already freed block (bit 14029)
[  855.420535] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586894:freeing already freed block (bit 14030)
[  855.436859] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586895:freeing already freed block (bit 14031)
[  855.453090] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586896:freeing already freed block (bit 14032)
[  855.469278] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586897:freeing already freed block (bit 14033)
[  855.485505] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586898:freeing already freed block (bit 14034)
[  855.501739] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586899:freeing already freed block (bit 14035)
[  855.517931] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586900:freeing already freed block (bit 14036)
[  855.534199] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586901:freeing already freed block (bit 14037)
[  855.550443] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586902:freeing already freed block (bit 14038)
[  855.566684] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586903:freeing already freed block (bit 14039)
[  855.582906] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586904:freeing already freed block (bit 14040)
[  855.599156] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586905:freeing already freed block (bit 14041)
[  855.615377] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586906:freeing already freed block (bit 14042)
[  855.631570] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586907:freeing already freed block (bit 14043)
[  855.647716] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586908:freeing already freed block (bit 14044)
[  855.663876] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586909:freeing already freed block (bit 14045)
[  855.680112] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586910:freeing already freed block (bit 14046)
[  855.696401] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586911:freeing already freed block (bit 14047)
[  855.712661] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586912:freeing already freed block (bit 14048)
[  855.728874] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586913:freeing already freed block (bit 14049)
[  855.745107] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586914:freeing already freed block (bit 14050)
[  855.761340] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586915:freeing already freed block (bit 14051)
[  855.777589] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586916:freeing already freed block (bit 14052)
[  855.793846] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586917:freeing already freed block (bit 14053)
[  855.810040] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586918:freeing already freed block (bit 14054)
[  855.826353] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586919:freeing already freed block (bit 14055)
[  855.842586] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586920:freeing already freed block (bit 14056)
[  855.858786] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586921:freeing already freed block (bit 14057)
[  855.875108] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586922:freeing already freed block (bit 14058)
[  855.891385] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586923:freeing already freed block (bit 14059)
[  855.907569] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586924:freeing already freed block (bit 14060)
[  855.923825] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586925:freeing already freed block (bit 14061)
[  855.940032] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586926:freeing already freed block (bit 14062)
[  855.956357] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586927:freeing already freed block (bit 14063)
[  855.972635] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586928:freeing already freed block (bit 14064)
[  855.988863] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586929:freeing already freed block (bit 14065)
[  856.005099] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586930:freeing already freed block (bit 14066)
[  856.021358] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586931:freeing already freed block (bit 14067)
[  856.037584] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586932:freeing already freed block (bit 14068)
[  856.053817] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586933:freeing already freed block (bit 14069)
[  856.069995] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586934:freeing already freed block (bit 14070)
[  856.086221] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586935:freeing already freed block (bit 14071)
[  856.102367] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586936:freeing already freed block (bit 14072)
[  856.118459] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586937:freeing already freed block (bit 14073)
[  856.134680] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586938:freeing already freed block (bit 14074)
[  856.150904] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586939:freeing already freed block (bit 14075)
[  856.167092] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586940:freeing already freed block (bit 14076)
[  856.183308] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586941:freeing already freed block (bit 14077)
[  856.199467] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586942:freeing already freed block (bit 14078)
[  856.215676] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586943:freeing already freed block (bit 14079)
[  856.231990] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586944:freeing already freed block (bit 14080)
[  856.248133] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586945:freeing already freed block (bit 14081)
[  856.264308] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586946:freeing already freed block (bit 14082)
[  856.280410] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586947:freeing already freed block (bit 14083)
[  856.296547] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586948:freeing already freed block (bit 14084)
[  856.312793] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586949:freeing already freed block (bit 14085)
[  856.329026] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586950:freeing already freed block (bit 14086)
[  856.345271] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586951:freeing already freed block (bit 14087)
[  856.361624] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586952:freeing already freed block (bit 14088)
[  856.377830] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586953:freeing already freed block (bit 14089)
[  856.394055] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586954:freeing already freed block (bit 14090)
[  856.410244] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586955:freeing already freed block (bit 14091)
[  856.426487] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586956:freeing already freed block (bit 14092)
[  856.442712] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586957:freeing already freed block (bit 14093)
[  856.459005] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586958:freeing already freed block (bit 14094)
[  856.475326] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586959:freeing already freed block (bit 14095)
[  856.491558] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586960:freeing already freed block (bit 14096)
[  856.507890] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586961:freeing already freed block (bit 14097)
[  856.524179] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586962:freeing already freed block (bit 14098)
[  856.540375] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586963:freeing already freed block (bit 14099)
[  856.556675] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586964:freeing already freed block (bit 14100)
[  856.572909] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586965:freeing already freed block (bit 14101)
[  856.589123] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586966:freeing already freed block (bit 14102)
[  856.605274] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586967:freeing already freed block (bit 14103)
[  856.621537] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586968:freeing already freed block (bit 14104)
[  856.637727] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586969:freeing already freed block (bit 14105)
[  856.653887] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586970:freeing already freed block (bit 14106)
[  856.670108] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586971:freeing already freed block (bit 14107)
[  856.686455] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586972:freeing already freed block (bit 14108)
[  856.702665] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586973:freeing already freed block (bit 14109)
[  856.718872] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586974:freeing already freed block (bit 14110)
[  856.735119] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586975:freeing already freed block (bit 14111)
[  856.751361] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586976:freeing already freed block (bit 14112)
[  856.767590] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586977:freeing already freed block (bit 14113)
[  856.783773] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586978:freeing already freed block (bit 14114)
[  856.799956] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586979:freeing already freed block (bit 14115)
[  856.816169] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586980:freeing already freed block (bit 14116)
[  856.832425] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586981:freeing already freed block (bit 14117)
[  856.848610] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586982:freeing already freed block (bit 14118)
[  856.864987] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586983:freeing already freed block (bit 14119)
[  856.881229] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586984:freeing already freed block (bit 14120)
[  856.897415] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586985:freeing already freed block (bit 14121)
[  856.913641] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586986:freeing already freed block (bit 14122)
[  856.929883] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586987:freeing already freed block (bit 14123)
[  856.946014] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586988:freeing already freed block (bit 14124)
[  856.962167] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586989:freeing already freed block (bit 14125)
[  856.978326] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586990:freeing already freed block (bit 14126)
[  856.994661] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586991:freeing already freed block (bit 14127)
[  857.010802] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586992:freeing already freed block (bit 14128)
[  857.026919] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586993:freeing already freed block (bit 14129)
[  857.043058] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586994:freeing already freed block (bit 14130)
[  857.059212] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586995:freeing already freed block (bit 14131)
[  857.075401] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586996:freeing already freed block (bit 14132)
[  857.091562] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586997:freeing already freed block (bit 14133)
[  857.107729] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586998:freeing already freed block (bit 14134)
[  857.123856] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1586999:freeing already freed block (bit 14135)
[  857.139889] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1587000:freeing already freed block (bit 14136)
[  857.156199] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1587001:freeing already freed block (bit 14137)
[  857.172339] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1587002:freeing already freed block (bit 14138)
[  857.188466] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1587003:freeing already freed block (bit 14139)
[  857.204598] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1587004:freeing already freed block (bit 14140)
[  857.220733] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1587005:freeing already freed block (bit 14141)
[  857.237004] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1587006:freeing already freed block (bit 14142)
[  857.253251] EXT4-fs error (device mmcblk0p2): mb_free_blocks:1300: group 48, block 1587007:freeing already freed block (bit 14143)
[  857.291693] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[  859.280789] mmc0: Timeout waiting for hardware interrupt - cmd25.
[  859.280842] mmc0: resetting ongoing cmd 25DMA before 61440/61440 [3]/[4] complete
[  859.283548] mmcblk0: error -110 transferring data, sector 2485504, nr 192, cmd response 0x900, card status 0x0
[  859.284695] blk_update_request: 109 callbacks suppressed
[  859.284723] end_request: I/O error, dev mmcblk0, sector 2485577
[  859.284741] end_request: I/O error, dev mmcblk0, sector 2485584
[  859.284756] end_request: I/O error, dev mmcblk0, sector 2485592
[  859.284932] end_request: I/O error, dev mmcblk0, sector 2485600
[  859.284955] end_request: I/O error, dev mmcblk0, sector 2485608
[  859.284970] end_request: I/O error, dev mmcblk0, sector 2485616
[  859.284984] end_request: I/O error, dev mmcblk0, sector 2485624
[  859.284997] end_request: I/O error, dev mmcblk0, sector 2485632
[  859.285010] end_request: I/O error, dev mmcblk0, sector 2485640
[  859.285024] end_request: I/O error, dev mmcblk0, sector 2485648
[  859.285065] Buffer I/O error on device mmcblk0p2, logical block 295328
[  859.285093] Buffer I/O error on device mmcblk0p2, logical block 295329
[  859.285109] Buffer I/O error on device mmcblk0p2, logical block 295330
[  859.285123] Buffer I/O error on device mmcblk0p2, logical block 295331
[  859.285136] Buffer I/O error on device mmcblk0p2, logical block 295332
[  859.285150] Buffer I/O error on device mmcblk0p2, logical block 295333
[  859.285176] Buffer I/O error on device mmcblk0p2, logical block 295334
[  859.285191] Buffer I/O error on device mmcblk0p2, logical block 295335
[  859.285206] Buffer I/O error on device mmcblk0p2, logical block 295336
[  859.285220] Buffer I/O error on device mmcblk0p2, logical block 295337
[  859.285232] Buffer I/O error on device mmcblk0p2, logical block 295338
[  859.285245] Buffer I/O error on device mmcblk0p2, logical block 295339
[  859.285258] Buffer I/O error on device mmcblk0p2, logical block 295340
[  859.285271] Buffer I/O error on device mmcblk0p2, logical block 295341
[  859.285297] Buffer I/O error on device mmcblk0p2, logical block 295342
[  859.285312] Buffer I/O error on device mmcblk0p2, logical block 295343
[  859.285326] Buffer I/O error on device mmcblk0p2, logical block 295344
[  859.285339] Buffer I/O error on device mmcblk0p2, logical block 295345
[  859.285353] Buffer I/O error on device mmcblk0p2, logical block 295346
[  859.285365] Buffer I/O error on device mmcblk0p2, logical block 295347
[  859.285378] Buffer I/O error on device mmcblk0p2, logical block 295348
[  859.285391] Buffer I/O error on device mmcblk0p2, logical block 295349
[  859.285417] Buffer I/O error on device mmcblk0p2, logical block 295350
[  859.285432] Buffer I/O error on device mmcblk0p2, logical block 295351
[  859.285455] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:250: I/O error writing to inode 343 (offset 0 size 98304 starting block 310712)
[  861.282673] mmc0: Controller never released inhibit bit(s).
[  861.284009] mmcblk0: unknown error -5 sending read/write command, card status 0xb00
[  861.284047] Buffer I/O error on device mmcblk0p2, logical block 9073
[  861.284075] lost page write due to I/O error on mmcblk0p2
[  861.284142] JBD2: Detected IO errors while flushing file data on mmcblk0p2-8
[  861.290012] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
gsh
Wed May 29, 2013 8:09 pm
Can you reproduce this without the USB hub, disk and TV dongle?
Also can you reproduce it with the overclocking?
If so it would be good if you could send the SDCard + Pi to us at Pi towers so I can finally reproduce the problem and maybe fix it! Will send a new one out...
Gordon
Gordon Hollingworth PhD
W. H. Heydt
Wed May 29, 2013 10:54 pm
Some questions... What are you using for a power supply? What gauge and length are the wires that supply the power to the Pi? If you are powering the Pi and other devices from a USB hub, what is the current rating on the USB hub power supply?
klricks
Thu May 30, 2013 3:49 am
The only time I had SD card corruption is when I set overclocking on. I had corruption within minutes. Never had a problem at normal clock speed.
I would suggest to turn overclocking off.
Aiiar
Sat Jun 01, 2013 5:24 pm
I have the same problem that the SD files corrupted! and I don't know why
I installed the asterisk again on the SD and after finishing setup extensions and while i editing some thing in the trunk from the web interface it didn't response and after restarting the pi and try to login from web I got this:
FATAL ERROR
DB Error: connect failed
Trace Back
/var/www/html/admin/libraries/db_connect.php:63 die_freepbx()
[0]: DB Error: connect failed
/var/www/html/admin/bootstrap.php:98 require_once()
[0]: /var/www/html/admin/libraries/db_connect.php
/etc/freepbx.conf:9 require_once()
[0]: /var/www/html/admin/bootstrap.php
/var/www/html/admin/config.php:105 include_once()
[0]: /etc/freepbx.conf
I don't know what and why this!!
paulk
Sat Jun 01, 2013 6:03 pm
To reiterate what a previous poster said..... I got my second rpi recently and trying to run it with the same sd card, power supply as my first rpi, resulted in file system corruption. The only fix was to turn off over-clocking. I suggest you try this. If it works with no over-clocking you can then try the various over-clocking settings until you find the fastest stable setting.
The simple fact of the matter is that not all rpi's are created equal. Some are more sensitive to dodgy power supplies and over-clocking.
Speedwell68
Sun Jun 02, 2013 5:28 am
What OS are you running?
gsh
Sun Jun 02, 2013 6:25 am
Please,
If you have a Pi / SDCard / Power supply combination that this happens on (fairly reliably) can you send it to me and I'll send out a new one for you?
Unfortunately otherwise it's never going to be fixed! I just haven't been able to reproduce the problem at pitowers...
PM me and I'll get your details...
Gordon
Aiiar
Sun Jun 02, 2013 6:56 am
paulk wrote:To reiterate what a previous poster said..... I got my second rpi recently and trying to run it with the same sd card, power supply as my first rpi, resulted in file system corruption. The only fix was to turn off over-clocking. I suggest you try this. If it works with no over-clocking you can then try the various over-clocking settings until you find the fastest stable setting.
Please, what is over-clocking and how to close it?
dave j
Sun Jun 02, 2013 9:48 am
Aiiar wrote:Please, what is over-clocking and how to close it?
Overclocking runs the chips faster than they normally go. It's disabled by default, so if you don't know what it is you are unlikely to have enabled it.
If you want to be sure, you can change the setting by entering the following into a command prompt:
sudo raspi-config
This will produce a menu of options, one of which is 'overclock'. Select that.
'OK' past the warning screen that appears.
You then get a list of overclock settings. Select 'None' and 'OK' that.
Then exit the program, selecting 'Yes' when it asks if you want to reboot.
xnosek00
Tue Jun 04, 2013 10:51 am
gsh wrote:Can you reproduce this without the USB hub, disk and TV dongle?
Gordon
Hi Gordon, thank you for reply. I'm trying to find, how to reproduce steps to SD card corruption.
After data corruption on SD card, I formatted SD card and install new system - everything was connected - TV dongle etc.
After 1 day - new data corruption. Raspi is overlocked - 950 MHz.
Next try - formating SD card, install new system on this SD card. But non of my Raspi's can't boot from this SD card. I change SD card - it's serveral days and everything is working. TV dongle is still connected.
Now about damaged SD card. A tested badblocks on corrupted SD card - nothing found. After several days i formatted corrupted SD card and Raspi's is booting from this card. I'm confused. Maybe it's bad SD card. I will try to find, how to reproduce sd card corruption, but I will need more time.
I had SD card corruption before. On other Raspi and on other SD card. It was still random - Raspi was overlocked, non overlocked, with usb hub and TV dongle, without usb hub and TV dongle.
I think - it's not problem on my own Raspi. At first - I have to find, how to reproduce steps, to SD card corruption, and than I can send you my Raspi, SD card or everything, what helps.
xnosek00
Tue Jun 04, 2013 10:55 am
W. H. Heydt wrote:Some questions... What are you using for a power supply? What gauge and length are the wires that supply the power to the Pi? If you are powering the Pi and other devices from a USB hub, what is the current rating on the USB hub power supply?
USB power suply, voltage is between 4.75 and 5.25, 1A. USB hub is self powered with power supply 5V,2A.
There was 1 TV card connected into the hub. There are 2 devices conected into the hub.
xnosek00
Wed Jun 05, 2013 8:13 pm
as I sad, I have new SD card. I was testing new tv dongle connected into self powered usb hub. So 2 USB dongles.
Instalation OK, TV working good, dmesg (no memory card corruption) - 1 hour working. After that i test rebooting.
First reboot, then dmesg:
[   12.523802] i2c /dev entries driver
[   23.239481] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[   23.864580] bcm2835-cpufreq: switching to governor ondemand
[   23.864610] bcm2835-cpufreq: switching to governor ondemand
[   30.461587] mmc0: Controller never released inhibit bit(s).
[   30.465418] mmcblk0: timed out sending r/w cmd command, card status 0x400d00
[   40.509981] mmc0: Timeout waiting for hardware interrupt - cmd25.
[   40.510022] mmc0: resetting ongoing cmd 25DMA before 4096/4096 [7]/[31] complete
[   40.514304] mmcblk0: error -110 transferring data, sector 1696048, nr 248, cmd response 0x900, card status 0x0
[   40.515426] end_request: I/O error, dev mmcblk0, sector 1696097
[   40.515456] end_request: I/O error, dev mmcblk0, sector 1696104
[   40.515475] end_request: I/O error, dev mmcblk0, sector 1696112
[   40.515494] end_request: I/O error, dev mmcblk0, sector 1696120
[   40.515512] end_request: I/O error, dev mmcblk0, sector 1696128
[   40.515529] end_request: I/O error, dev mmcblk0, sector 1696136
[   40.515547] end_request: I/O error, dev mmcblk0, sector 1696144
[   40.515564] end_request: I/O error, dev mmcblk0, sector 1696152
[   40.515581] end_request: I/O error, dev mmcblk0, sector 1696160
[   40.515597] end_request: I/O error, dev mmcblk0, sector 1696168
[   40.515907] Aborting journal on device mmcblk0p2-8.
[   40.529418] mmc0: Controller never released inhibit bit(s).
[   40.531076] mmcblk0: unknown error -5 sending read/write command, card status 0xb00
[   42.038279] EXT4-fs error (device mmcblk0p2): ext4_journal_start_sb:349: Detected aborted journal
[   42.062427] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
SD card was little bit damaged. Fsck repairs everything.
After that - configuring system and severals reboots. 5 reboots OK (nothing in dmesg and everything works). It look's like, that I have everything done. The last reboot (6th) - after that, my filesystem on SD card is damaged. Missing folders: /usr, /etc
there is my dmesg after 6th reboot:
[   10.928378] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   11.360641] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   12.453776] i2c /dev entries driver
[   22.159292] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[   23.774959] bcm2835-cpufreq: switching to governor ondemand
[   23.775039] bcm2835-cpufreq: switching to governor ondemand
[   30.277286] mmc0: Controller never released inhibit bit(s).
[   30.281164] mmcblk0: timed out sending r/w cmd command, card status 0x400d00
[   35.453907] mmc0: Controller never released inhibit bit(s).
[   35.457924] mmcblk0: timed out sending r/w cmd command, card status 0x400d00
[   37.517301] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SS
[   46.180270] mmc0: Controller never released inhibit bit(s).
[   46.183912] mmcblk0: timed out sending r/w cmd command, card status 0x400d00
[   51.315050] mmc0: Controller never released inhibit bit(s).
[   51.318712] mmcblk0: timed out sending r/w cmd command, card status 0x400d00
[   72.230008] mmc0: Timeout waiting for hardware interrupt - cmd25.
[   72.230052] mmc0: resetting ongoing cmd 25DMA before 4096/4096 [2]/[27] complete
[   72.233168] mmcblk0: error -110 transferring data, sector 1696840, nr 216, cmd response 0x900, card status 0x0
[   72.234281] end_request: I/O error, dev mmcblk0, sector 1696849
[   72.234309] end_request: I/O error, dev mmcblk0, sector 1696856
[   72.234331] end_request: I/O error, dev mmcblk0, sector 1696864
[   72.234350] end_request: I/O error, dev mmcblk0, sector 1696872
[   72.234368] end_request: I/O error, dev mmcblk0, sector 1696880
[   72.234386] end_request: I/O error, dev mmcblk0, sector 1696888
[   72.234404] end_request: I/O error, dev mmcblk0, sector 1696896
[   72.234422] end_request: I/O error, dev mmcblk0, sector 1696904
[   72.234439] end_request: I/O error, dev mmcblk0, sector 1696912
[   72.234456] end_request: I/O error, dev mmcblk0, sector 1696920
[   72.234784] Aborting journal on device mmcblk0p2-8.
[   72.234899] EXT4-fs error (device mmcblk0p2) in ext4_new_inode:933: Journal has aborted
[   72.250042] EXT4-fs error (device mmcblk0p2) in ext4_new_inode:933: Journal has aborted
[   72.268804] mmc0: Controller never released inhibit bit(s).
[   72.275703] mmcblk0: unknown error -5 sending read/write command, card status 0xb00
[   72.276411] mmc0: resetting ongoing cmd 18DMA before 4096/4096 [1]/[1] complete
[   72.277586] mmcblk0: error -84 transferring data, sector 4317232, nr 8, cmd response 0x900, card status 0x0
[   72.277605] mmcblk0: retrying using single block read
[   72.277972] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   72.278407] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   72.278841] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   72.279283] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   72.279716] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   72.280144] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   72.281098] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   72.281534] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   72.281960] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:741: group 22, 10208 clusters in bitmap, 10480 in gd
[   72.305411] EXT4-fs (mmcblk0p2): delayed block allocation failed for inode 156160 at logical offset 173 with max blocks 8 with error -30
[   72.338449] EXT4-fs (mmcblk0p2): This should not happen!! Data will be lost
[   72.338449]
[   72.361004] EXT4-fs error (device mmcblk0p2) in ext4_da_writepages:2398: Journal has aborted
[   82.310004] mmc0: Timeout waiting for hardware interrupt - cmd18.
[   82.310048] mmc0: resetting ongoing cmd 18DMA before 12288/12288 [28]/[28] complete
[   82.311278] mmcblk0: error -110 transferring data, sector 1058872, nr 256, cmd response 0x900, card status 0x0
[   82.311322] mmcblk0: retrying using single block read
[   82.311953] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.312553] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.313161] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.313772] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.314376] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.314994] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.315609] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.316225] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.316816] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.317306] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.317794] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.318281] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.318772] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.319261] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.319776] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.320276] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.321534] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.322053] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.322547] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.323035] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.323528] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.324021] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.324512] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.325001] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.325492] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.325983] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.326473] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.326968] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.327461] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.327959] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.328448] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.328941] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.329430] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.329920] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.331191] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.331726] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.332231] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.332735] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.334146] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.334654] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.335149] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.335681] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.336171] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.336655] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.337141] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.337643] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.338270] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.338767] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.339254] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.339742] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.340242] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.341338] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.341928] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.342428] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.342917] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.343441] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.343933] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.344420] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.344904] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.345390] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.345877] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.346370] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.346872] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.347361] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.347849] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.348452] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.349054] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.349657] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.350272] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.351364] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.351941] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.352535] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.353164] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.353691] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.354213] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.354734] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.355263] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.355791] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.356316] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.356837] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.357360] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.357884] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.358407] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.358931] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.359454] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.360025] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.361258] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.361811] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.362499] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.363031] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.363556] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.364079] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.364607] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.365139] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.365672] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.366200] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.366718] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.367246] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.367794] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.368318] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.368837] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.369358] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.369880] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.370478] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.371438] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.371979] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.372566] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.373091] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.373626] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.374156] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.374688] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.375249] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.375796] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.376325] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.376845] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.377362] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.377879] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.378397] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.378915] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.379435] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.380007] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.381243] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.381793] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.382330] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.382855] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.383376] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.383912] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.384430] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.384954] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.385558] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.386169] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.386778] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.387383] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.388008] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.388617] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.389238] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.389823] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.390322] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.391375] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.391889] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.392381] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.392877] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.393367] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.393857] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.394348] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.394836] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.395323] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.395809] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.396295] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.396781] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.397265] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.397757] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.398242] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.398729] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.399240] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.399750] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.400248] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.401428] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.401934] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.402424] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.402917] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.403403] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.403897] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.404385] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.404872] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.405356] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.405844] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.406327] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.406809] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.407293] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.407807] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.408290] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.408784] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.409278] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.409777] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.410286] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.411444] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.411950] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.412450] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.412983] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.413471] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.413952] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.414434] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.414922] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.415405] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.415894] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.416377] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.416858] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.417339] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.417819] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.418299] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.418779] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.419258] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.419862] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.420482] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.421455] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.422047] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.422640] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.423260] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.423844] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.424470] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.424988] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.425506] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.426024] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.426557] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.427086] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.427604] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.428122] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.428640] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.429162] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.429683] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.430214] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.431387] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.431941] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.432478] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.433019] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.433546] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.434065] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.434594] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.435123] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.435647] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.436165] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.436682] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.437199] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.437724] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.438243] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.438761] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.439287] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.440074] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.441385] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.441946] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.442483] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.443002] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.443528] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.444044] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.444562] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.445088] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.445614] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.446141] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.446667] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.447180] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.447730] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.448246] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.448762] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.449278] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.449791] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.450319] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.451444] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.451967] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.452488] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.453003] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.453554] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.454071] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.454584] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.455096] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   82.455609] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   92.470003] mmc0: Timeout waiting for hardware interrupt - cmd18.
[   92.470043] mmc0: resetting ongoing cmd 18DMA before 4096/4096 [1]/[1] complete
[   92.471199] mmcblk0: error -110 transferring data, sector 1139648, nr 8, cmd response 0x900, card status 0x0
[   92.471221] mmcblk0: retrying using single block read
[   92.471772] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   92.472264] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   92.472749] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   92.473237] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   92.473720] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   92.474209] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   92.474691] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[   92.475171] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[  102.490002] mmc0: Timeout waiting for hardware interrupt - cmd25.
[  102.490065] mmc0: resetting ongoing cmd 25DMA before 4096/4096 [1]/[1] complete
[  102.491258] mmcblk0: error -110 transferring data, sector 1695744, nr 8, cmd response 0x900, card status 0x0
[  102.502658] mmc0: Controller never released inhibit bit(s).
[  102.510510] mmcblk0: unknown error -5 sending read/write command, card status 0xb00
[  102.510541] blk_update_request: 48 callbacks suppressed
[  102.510555] end_request: I/O error, dev mmcblk0, sector 122880
[  102.510576] Buffer I/O error on device mmcblk0p2, logical block 0
[  102.510587] lost page write due to I/O error on mmcblk0p2
[  102.520845] EXT4-fs error (device mmcblk0p2) in ext4_create:2120: Journal has aborted
[  102.533257] EXT4-fs error (device mmcblk0p2) in ext4_create:2120: Journal has aborted
[  102.510643] EXT4-fs error (device mmcblk0p2): ext4_journal_start_sb:349: Detected aborted journal
[  102.555129] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
[  102.570089] EXT4-fs error (device mmcblk0p2): ext4_journal_start_sb:349: Detected aborted journal
[  102.581623] EXT4-fs error (device mmcblk0p2): ext4_journal_start_sb:349: EXT4-fs error (device mmcblk0p2): ext4_journal_start_sb:349: Detected aborted journal
[  102.601523] Detected aborted journal
[  102.604486] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
[  102.617590]
[  102.617631] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
[  102.639472]
[  102.639552] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
[  102.629305] EXT4-fs error (device mmcblk0p2): ext4_journal_start_sb:349: Detected aborted journal
[  102.699376] EXT4-fs (mmcblk0p2): ext4_da_writepages: jbd2_start: 3072 pages, ino 156160; err -30
distro: raspbian
updated: today
firmware updated: today
xnosek00
Re: filesystem corruption - unstable raspberry
Wed Jun 05, 2013 8:29 pm
summary of my usage my Pi:
self powered hub, tv dongle, usb disk, no datacorruption after reboot - it looks like stable. It runs maybe 1 or 2 months (without rebooting).
after rebooting and changing usb dongles - prying is needed. Sometimes is ok, sometimes - damaged sd card.
Wed Jun 05, 2013 8:38 pm
When you say "rebooting" are you using the "shutdown" command or just yanking the power off?
Despite advances in Linux file system software it seems yanking the power is a recipe for disaster.
Anyway, I await an answer to this question because as of now I have been through a dozen cards in half a year that have all ended up in terminal failure. As in, nothing can format or write correctly to them.
xnosek00
Wed Jun 05, 2013 8:41 pm
Heater wrote:When you say "rebooting" are you using the "shutdown" command or just yanking the power off?
good thought, but I'm rebooting by typing: sudo reboot
so - standard reboot - not yanking the power off
Wed Jun 05, 2013 8:54 pm
That just leaves us with advice about power supply quality. I have tried a few and measured them to be within advised limits. Still SD cards of different sizes, classes and brands continue to drop by the way side. I really have to give up when "dd" tells me it cannot read back what I just wrote.
Mind you it's noy just the Pi I have a couple of other types of ARM boards here that also eat cards for breakfast.
What to do?
Mcrunxman
Thu Dec 12, 2013 12:20 am
I have used about 20 model b units and the problem is fairly consistent when using debian 2013-09-25 distro and any over clocking. Reduced occurrence without over clocking but still often enough to be a problem and definitely when power is lost.
Returned to previous version, march 2013, and no over clocking and the system runs great, even survives power loss. All systems running 24/7 365 and stable. I won't attempt to upgrade until a new debian distro is available.
By the way system load under the earlier distro is lighter. I would be interested to hear if anyone else has seen the same instability with the current debian image.
