Request: Minimal Raspbian image
Posted: Wed May 29, 2013 3:16 pm
by chrisb
It would be nice to have an "official" minimal Raspbian image that boots to command line. It would be good for servers, where a full graphical desktop + extras isn't required.
Re: Request: Minimal Raspbian image
Posted: Wed May 29, 2013 3:20 pm
by chrisb
Also it would be useful if the download page stated the file size of each download.
Posted: Wed May 29, 2013 3:27 pm
by RaTTuS
Posted: Wed May 29, 2013 3:49 pm
by chrisb
It sounds like that version still has a desktop, in fact it would be the same download size, they just eliminated the empty space from the file system.
Posted: Wed May 29, 2013 3:52 pm
by chrisb
Though from that thread I did find http://www.raspberrypi.org/phpBB3/viewt ... 66&t=14728 the 100MB so called "Raspbian Server Edition", would be nice to see an official version.
Posted: Wed May 29, 2013 3:57 pm
by jamesh
We try and avoid too many official versions.
Although I use stock Raspbian, and have never used the desktop (boot to console) so what we have now will probably fit the bill anyway.
Posted: Wed May 29, 2013 4:12 pm
by chrisb
jamesh wrote:We try and avoid too many official versions.
I understand the problems of version proliferation, but a minimal install would really just be a subset of the current full desktop install. The actual software would be the same, but people would download 100MB or so installer rather than 500MB or so, and once installed would have more free space. Most linux distributions support a minimal install/iso for this reason. (Yes, a user could download the full desktop version, install it and then remove as much as possible, but that takes longer and is more complicated)
Posted: Wed May 29, 2013 4:53 pm
by DeeJay
Another thread that might be of interest -
http://www.raspberrypi.org/phpBB3/viewt ... 20#p343120
It won't provide any benefit over raspbian, since this is still raspbian. It just doesn't come with the bloat that 'the' raspbian images have. It's handy if you want a minimal distro without rolling your own or removing packages. Great for a headless server set up or small sd cards.
Posted: Fri Jun 07, 2013 6:02 pm
by pluggy
Install standard Raspdian
run my script :
#!/bin/bash
# Stephen's Raspberry Pi Mimimalist install from standard Raspdian Image
apt-get update
apt-get purge xserver* -y
apt-get purge ^x11 -y
apt-get purge ^libx -y
apt-get purge ^lx -y
apt-get purge samba* -y
apt-get autoremove -y
apt-get upgrade -y
apt-get clean
Nothing magic just takes a lot of the X stuff out.
Posted: Fri Sep 26, 2014 4:45 pm
by technix
I am still in need for such minimal images for headless systems that is only accessed either over SSH or over UART. Currently I take the official Raspbian image which is a 1.5GB download and expands to a 3.3GB image, purge all GUI and not-so-used parts and shrink the image down to ~800MB and build from that point. It takes a long time to throw away all the GUI.
To me, as a server, even a router, the GUI stack's existence is useless and does more harm than benefit as they added attacking vectors to my system. Servers and routers are supposed to be security hardened.
Usually my final image is about the same size as the official, but with the GUI replaced with a full LAMP (Debian jessie/sid, apache2, mariadb-server, php5) stack or a router basics stack (Debian jessie/sid, bridge-utils, vlan, ufw, ntop, pppoeconf, nginx, miniupnpd)
Posted: Fri Sep 26, 2014 7:14 pm
by andrum99
A big user of space on the SD card is Mathematica. I use the following to remove it and Java from my Raspbian install as I have no need for them:
sudo apt-get purge wolfram-engine java-common oracle-java8-jdk
Note that versions of Raspbian before the 2014-09-09 release have Java 7 installed instead of Java 8 so you would need to alter the above command accordingly.
I also use
sudo apt-get clean
after each time I update the system.
Posted: Fri Sep 26, 2014 7:21 pm
by andrum99
technix wrote:I am still in need for such minimal images for headless systems that is only accessed either over SSH or over UART. Currently I take the official Raspbian image which is a 1.5GB download and expands to a 3.3GB image, purge all GUI and not-so-used parts and shrink the image down to ~800MB and build from that point. It takes a long time to throw away all the GUI.
Bear in mind that the Raspberry Pi Foundation's primary focus is on education. I think it is unlikely that you will see the foundation releasing an official minimal server version of Raspbian, but there is nothing to stop anyone else from producing a minimal distro. There is a tool to build Raspbian distros available at https://github.com/asb/spindle.
Posted: Fri Sep 26, 2014 9:01 pm
by patrikg
Posted: Fri Sep 26, 2014 9:24 pm
by DougieLawson
The best thing I've found it raspbian-ua-netinst. That gets a very minimal Wheezy or Jessie system and you can add packages from the normal Raspbian.org repositories.
Posted: Sun Nov 30, 2014 3:51 pm
by goci
Would be great if Mr Upton's team consider this;
As Raspberry pi users learn more stuff on the Pi, they would want to customize it their way based on the very basic minimal distro.
What do you guys think of minbian? ... Seems like a good compromise and seems to be quite loyal at not tampering with the out of the box official image
http://minibianpi.wordpress.com/about/
Will be putting more comments on this Minibian soon as I download it and give it a go.
Posted: Sun Nov 30, 2014 4:16 pm
by patrikg
Posted: Sun Nov 30, 2014 4:45 pm
by emgi
How about my all-time favorite: http://www.slitaz.org/en/ ? 8-)
Since recently they are also developing a RPi version.
If you are looking for a minimal yet stable linux OS, this is a viable candidate.
The no-desktop version is: slitaz-rpi-base-20140329 (22 Mb)
/emgi
