GTBecker
amixer source code?
Sun May 26, 2013 9:12 pm
Where can I find the current (1.0.25 in Raspian) amixer source code? It's probably right under my nose but I've exhausted my patience searching for it.
TIA.
Tom
DirkS
Re: amixer source code?
Sun May 26, 2013 9:30 pm
You can install the sources pretty much the same as the program itself.
You have to add a deb-src line to /etc/apt/sources.list:
deb-src http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
Which is almost a copy of the line that's already there. The only difference is that it has 'deb-src' instead of 'deb' at the start of the line.
Then run the following commands:
sudo apt-get update
sudo apt-get source alsa-utils
And the source should be downloaded.
If you want to compile it you probably also have to run
sudo apt-get build-dep alsa-utils
to resolve dependencies
I hope I got this right ;)
Gr
Dirk.
GTBecker
Sun May 26, 2013 9:59 pm
I vaguely recall reading that somewhere - now that you remind me. Brain fade...
Thanks.
Tom
