milesma
[Solved] fail on kindleberry pi's setting
Fri May 24, 2013 4:13 pm
Hi guys,
I'm following this link:
http://projectdp.wordpress.com/2012/09/ ... pberry-pi/
I've done smoothly step 1~4.
Basically, on step "5.0 Pi: Boot into your kindle user’s account on tty1 -auto"
I can not sort it out by either "1:2345:respawn:/sbin/agetty -a kindle -8 -s tty1 linux" or " 1:2345:respawn:/bin/login -f kindle tty1</dev/tty1>/dev/tty1 2>&1"
And in step "5.2 Pi: Configure ssh passwordless logins – auto", I don't have a folder as described " cd /home/kindle/.ssh/" (the last .ssh is not there).
So any suggestions?
Or anyone know what step 5's script mean?
Thank you
pluggy
Re: fail on kindleberry pi's setting
Fri May 24, 2013 6:20 pm
the .ssh folder is created when you first use the ssh command to connect to a remote machine. You could try making the folder by hand beforehand
If you're logged into the pi as the kindle user its just
cd ~
mkdir .ssh
milesma
Sat May 25, 2013 3:48 am
Thanks Guys. The problem is solved.
Basically, the following script works for me.
The thing I've missed is a setting to disable log into xwindow directly.
After use raspi-config to change this option, all good! I can use kindle as a sole display now.
Who is online
Users browsing this forum: Jednorozec, mikerr, stubright and 39 guests
