DanyalC1995
Problem with Raspberry Pi Camera
Wed May 22, 2013 1:58 pm
I am having a problem with my camera or so the commands. When I type in raspistill -o image.jpg I get -bash: raspistill: command not found. I have updated wheezy and enabled the camera also.
Re: Problem with Raspberry Pi Camera
Wed May 22, 2013 2:22 pm
Odd, I just did an "apt-get update" and "apt-get upgrade" on my raspian which had not been updated for the last half a year. For sure I now have the raspistill command available. And raspivid. Only problem is I don't have a camera:(
leol
Wed May 22, 2013 4:27 pm
is raspistill in /opt/vc/bin?
is raspistill in /usr/bin ?
if so, is it a link to /opt/vc/bin/raspistill?
Does your PATH include /usr/bin?
DanyalC1995
Wed May 22, 2013 6:07 pm
I cannot find that raspistill in any of those dircetories
Wed May 22, 2013 6:25 pm
DanyalC1995 wrote:I cannot find that raspistill in any of those dircetories
Then your update/upgrade has failed in some way. Try them again.
sudo apt-get update
sudo apt-get upgrade
texy
Sun May 26, 2013 10:23 am
leol wrote:is raspistill in /opt/vc/bin?
I have a question about PATH as I have a new image whereby I must use /opt/vc/bin/raspistill instead of just raspistill, ie my PATH does not include /opt/vc/bin
What is the best method to change this to either just user pi, or all users?
Thanks,
Texy
texy
Sun May 26, 2013 10:58 am
To answer my own question :
[email protected] ~ $ echo 'export PATH=$PATH:/opt/vc/bin' >> ~/.bashrc
and a reboot will add the path and make it permanent. The example above will only modify the PATH for user pi - log in as root (or whoever) and repeat as neccessary.
Texy
