tech_monkey
Re: How about this for a case.
Thu Mar 29, 2012 3:09 pm
Been thinking about a case for when I finally get a PI. Still waiting for RS to email me.
so thought about re-using this case I had for an Espresso PC.
Don't know if I can get the touchpad to work.
http://www.casatech.eu
john_wage
Thu Mar 29, 2012 3:34 pm
That's not a case, it's a piece of plastic molded around a circuit board, rather ambitious I'd say..
(Not trying to shoot down your project, but you will see what I mean once you have your RPi, and that case cracked open next to eachother.)
tech_monkey
Thu Mar 29, 2012 4:22 pm
It is a case, I have taken the case apart loads of times. First time was to put in a 40Gb hard drive.
ProDigit
Thu Mar 29, 2012 5:14 pm
probably an external harddrive case would work well??
You'd also have no use for the screen, I suppose. (that is a screen it has on the picture, isn't it?)
tech_monkey
Thu Mar 29, 2012 6:03 pm
@Prodigit
Erh no that's why I said touchpad.
The original board had a 1Ghz cpu, ran windows 98 and had 512mB ram though you could have 1gb but as a sodim module it was quite expensive back then for the 1gb.I also ran Ubuntu on it for a while until the hard drive died.
I have also thought about using an external hard drive case too, as I have one of these spare.
