Raspberry Pi not Booting
Posted: Tue May 21, 2013 8:57 am
I have been using a Raspberry Pi Modal B (Origional) for the past three months(ish) and have started to have a problem. I leave it plugged in, connected an ethernet cable and inside a case (from ModMyPi). I normally use SSH to access it when ever is necessary. Yesterday I tried to connected to it, but upon scanning my network it was not listed. I dug out out from behind the router and discovered that the green OK light was off, and only the power light was working. I connected it to my moniter (which it has worked with before) and saw that it was unable to find the OS on the SD card. I decided to reinstall the OS (Wheezy 2013-02-09). After installing it and rebooting the Pi, it showed nothing on the monitor and the green light does not light at all. I checked the elinux board and tried replacing the bootcode.bin but it still won't boot. Any ideas?
FAQ:
FAQ:
- It is at room temp
I have not modified the board in any way
The SD card is not 'Locked'
The HDMI cable works
I am using a 5v phone charger to power it
If I press down on the SD card when I plug it in, I get three green LED flashes, which means start.elf was not found or loader.bin was not found. I have checked the SD card, and start.elf is there, however loader.bin is not. According to ELinux, loader.bin is not needed.
