tubsids
[SOLVED] Update...Upgrade...then WLAN does not work [SOLVED]
Tue May 14, 2013 10:10 am
Hi together,
Yesterday i did with RaspberryPi
update
then upgrade
and now wireless does not work
iwconfig finds it not
ifconfig will not show well-Fi
lo no wireless extensions.
eth0 no wireless extensions.
lsusb
answer
Bus 001 Device 004: ID 0846:9041 NetGear, Inc. WNA1000M 802.11bgn [Realtek RTL8188CUS]
other device works with WLAN2 but is larger and I want to have older usb dongle back in operation
Do you have ideas?
remsnet
Contact: Website Yahoo Messenger
Re: Update...Upgrade...then WLAN does not work
Tue May 14, 2013 10:17 am
tubsids wrote:Hi together,
update
then upgrade
lsusb
answer
Do you have ideas?
your kernel module may gone away after kernel update.
do an
lsmod
zcat /proc/config.gz | grep -i rtl
if no module loaded , folow this forum thread:
http://www.raspberrypi.org/phpBB3/viewt ... &start=125
tubsids
Tue May 14, 2013 10:21 am
lsmod
Module Size Used by
8192cu 490305 0
CONFIG_USB_RTL8150=m
CONFIG_RTL8187=m
CONFIG_RTL8187_LEDS=y
CONFIG_RTL8192CU=m
CONFIG_DVB_USB_RTL28XXU=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
# CONFIG_RTLLIB is not set
sudo /boot/install-rtl8188cus-latest.sh
This script will install the driver for Realtek RTL8188CUS based wifi adapters.
To see a list of wifi adapters using this driver take a look at the document at
http://dl.dropbox.com/u/80256631/install-rtl8188cus.txt
1. It can install a n...
2. It can install a ...
3. If the driver is already installed it wil...
4. It can repair a brok...
The script will also give you the option to update the software and firmware to
the latest versions using apt-get update, apt-get upgrade and rpi-update.
Press any key to continue...
An RTL8188CUS driver module is installed and loaded.
You have 1 wifi adapter configured.
wlan0 is configured but is not installed.
The Pi has an internet connection.
Any files needed for the installation/upgrade will be downloaded from the
Internet unless they have already been copied to the SD card /boot directory.
Unrecognised software version: Linux raspberrypi 3.6.11+ #446 PREEMPT Fri May 10 20:17:25 BST 2013 armv6l GNU/Linux
Downloading the latest script.
The script you're using is the latest version.
Aborting the rtl8188cus installation script.
MrEngman
Tue May 21, 2013 12:08 am
The wifi driver was recently updated to a new version and a patch to enable the WNA1000M was missing so the WNA1000M stopped working. This has been fixed with the very latest version that can be updated to using command sudo rpi-update. If you don't have rpi-update you can install it with the command sudo apt-get install rpi-update.
Also the script has been updated as well. Rerun the script and it should load the latest version that recognises the new kernel versions.
MrEngman
tubsids
Tue May 21, 2013 8:25 am
Thanks a lot. The last replay from MrEngman helped me.
Thanks !!!
-- SOLVED --
