Re: RasbPi powered by the USB port on a TV
Posted: Sat Mar 24, 2012 7:10 pm
by anthill
Hello, well I guess this is fairly self explanatory.
Will the USB ports found on a lot of HD TV's power the Pi?
There must be a fair amount of current pulled through them as they power external HD's plugged into them when using the media player features!
Any idea's?
Posted: Sat Mar 24, 2012 7:42 pm
by dom
Works for me.
Posted: Sat Mar 24, 2012 10:46 pm
by HansH
Yep, saves you an adapter.
Posted: Sun Mar 25, 2012 5:28 pm
by Jessie
In a majority of cases this should be no issue. The 500mA minimum that is avalible from the TV USB ports should boot it just fine. I say should because 500mA is the min and that is enough to power the R-Pi and a couple accesories. Try to spin up a small hard drive plus the R-Pi on that port and unless the TV maker made a good amount of power avalible on that port you will run into issue. But, a KB/Mouse, wifi, SD card, and USB stick plus the Pi should not be an issue.
Posted: Mon Apr 09, 2012 7:57 pm
by anthill
Thanks for the replies, I can't wait to get my hands on the Pi and start playing!
Posted: Tue Apr 10, 2012 8:39 pm
by rustyk123
Check your TV first before assuming, some provide power only on startup, some only in Firmware upgrade mode, and some all the time. Just plug a mobile external hard drive (2.5", with no external power supply) in and listen for it to spin up, and keep spinning for a minute or so. If the ports power is low, it would either click, spin then go off, or do nothing. If it provides no power it will not do anything.
If yours provides low or no power, just go on eBay or some other website and buy a cheap usb power adapter, the very cheap iPhone adapters (like $3 should work perfectly, they don't work on iPhone, but perfect for anything else). You may also be able to use something like the older Motorola adapters the use mini USB connectors, that way the cord is included and built-in.
Posted: Tue Apr 10, 2012 9:36 pm
by n31l
If the port is USB compliant then it would not work. But so many USB ports aren’t so it would. A USB port should not provide more than 100mA unless the connected device negotiates for the full 500mA. We have pulled over 1.5A out of a few laptops that just connect the 5V to their internal power rail.
So far non-compliant is the norm in the laptops we’ve looked at.
Posted: Thu Apr 12, 2012 4:41 am
by Jessie
1.5A is becomming common. Many products tout this as a feature that allows faster charging of portible devices. On my PC the 1.5A ports are color'ed red. They are still regulated ports and are working as intended.
