Fri May 10, 2013 9:05 pm
ramb0 wrote:
Trev, i'm interested in your reasonings behind recommending against powering the 2.5" USB HDD with a Y cable?
The Y cable method assumes that the hub can supply up to 500mA per port - one part of the Y is power + data, the other (newer types have a red plug) power only. However, in practice, this only appears to be true for "motherboard hubs" (eg. my Acer netbook). All of the "powered" USB hubs I've checked appear to have their ports connected in parallel and hence, apart from a slightly reduced cable resistance, using two ports gains nothing (and you lose the use of that port for anything else). Many "older" 2.5" drives require transient currents up to 1A (on motor spin-up or head seek) and, to my cost, I've ended up with three drives becoming unusable due to MBR corruption (could not be re-formatted) after trying to use them on a powered hub. If powered via their separate power socket (where it existed) I had no problems. Additionally, any PSU used with a powered hub needs to be able to supply the total maximum current for all ports if required to perform at full spec. (ie. for a 4-port hub - 2A). Apart from losing the drives mentioned above, the main reason I investigated deeper was the inability of such hubs to work with a "Y-connected" CD/DVD drive originally supplied with a Median laptop some years ago, and which otherwise worked with three newer netbooks. To date I've only managed to get that to work with a Hama hub powered from a 5V 2A supply. Hope this clarifies matters somewhat.
Trev.
