franzhartwig
Re: RPi-Monitor : Raspberry Pi self monitoring software
Wed Sep 04, 2013 7:47 am
I am sorry about your decision, advising users to upgrade from Ubuntu 12.10 to 13.04. 12.10 is supported until april 2014, no need to upgrade to 13.04. Not supporting Firefox 23 (the standard browser, recent version) with Ubuntu 12.10 (not recent but supported, yet) is somewhat strange.
Xav
Wed Sep 04, 2013 7:58 am
franzhartwig wrote:I am sorry about your decision, advising users to upgrade from Ubuntu 12.10 to 13.04. 12.10 is supported until april 2014, no need to upgrade to 13.04. Not supporting Firefox 23 (the standard browser, recent version) with Ubuntu 12.10 (not recent but supported, yet) is somewhat strange.
I'm also sorry about that but you should understand that I do this job on my free time and I'm giving you the access to my work for free.
So you should also understand that I'll not spend time to try to fix an issue for only one person which is whilling to use an outdated version of OS which will no more be supported in around 6 mounths...
franzhartwig
Sat Sep 07, 2013 9:22 am
Of course, you are right. It's your personal time you're offering. RPi-Monitor works very fine (apart the Ubuntu-12.10 issue ...). I have implemented a reverse proxy with apache - an easy way to add https and user authentication to RPi-Monitor.
I am sorry for blaming you - now using RPi-Monitor with Chromium.
Xav
Sat Sep 07, 2013 9:31 am
RPi-Monitor v2.4 is available.
Here is the list of modifications:
  • * Change shared memory management to fix issue #12 and define the shmkey in configuration file
    * Added the possibility to define the default timeline to be display in statistics page (from an idea given by a user :-) )
    * Add -s (show) option to show configuration as loaded (useful for advanced customization) (also from an idea given by a user :-) )
    * Added WiFi icon
Access to version 2.4 from my blog: http://rpi-experiences.blogspot.fr/
Enjoy and spread the word to your circle!
Xav
Tue Oct 15, 2013 11:50 am
RPi-Monitor v2.5 is available.
  • * Fix issue #16: (v2.4) Network Graph displaying Bytes/s not in bits/s (wrong Legend) (From deMartin)
    * Update configuration to be compatible with NOOBS as proposed in issue #17 (From deMartin)
    * Implement modification for small screen proposed in issue #18 (From deMartin)
    * Change footer to better fit with small screens
    * Implement pull request #20: Counting buffers and cache as available memory (From Harbulot)
    * Add the possibility to set Min and Max values for rrd graphs in configuration file (issue #19 #21)
Access to this version from my blog: http://rpi-experiences.blogspot.fr/
Xav
Mon Oct 21, 2013 9:55 am
RPi-Monitor v2.5.1 is available fixing a bug in graphs display.
  • * Update rrd graph with unkown data if fetched information is not a valid number
    * Fix issue #22 : empty.rrd file not properly generated
Xav
Sun Mar 16, 2014 2:32 pm
Version 2.6 of RPI-Monitor is available.
Here is the change log of this new version
  • Add version.json, menu.json and friends.json generation to fix issue #25
  • Check is file is executable (instead of existing) to define if it should be executed
  • Generate empty.rrd at each request to fix issue #23
  • Generate empty.rrd at each start workaround for issue #23 when using an external web server
  • Improve shellinabox management <IP>/shellinabox forwards to https://<IP>:4200
  • Add RPi-Monitor Interactive Configuration Helper
richiepp
Sun Mar 16, 2014 2:51 pm
I'm having the same problem and get the same error message. :(
I've installed the dependencies.
What else can I try?
Rich
Xav
Sun Mar 16, 2014 3:02 pm
richiepp wrote:I'm having the same problem and get the same error message. :(
Rich
Hi Rich,
I think you should first "try" to describe you problem and error message;) :D
I don't heve enough information to be able to understand your issue ad help you.
Rgds,
Xav
richiepp
Re: RPi-Monitor Version 2.6 is available
Sun Mar 16, 2014 4:12 pm
Same errors as Bernie H was getting
dpkg: error processing rpimonitor (--install):
dependency problems - leaving unconfigured
Processing triggers for man-db ...
rpimonitor
Xav
Sun Mar 16, 2014 4:18 pm
richiepp wrote:Same errors as Bernie H was getting
rpimonitor
What is your Distro?
What are the command entered (and their result)?
Did you succeed to install RPi-Monitor in the past? Which version?
richiepp
Sun Mar 16, 2014 4:36 pm
I got it working!! I had to retry installing the dependencies three times. 3 is the magic number and it's working.
Rich
plugwash
Sun Mar 16, 2014 11:47 pm
Bernie.H wrote:Sorry, but this didn't work for me. Followed install instructions and I go
t the following:
dpkg: dependency problems prevent configuration of rpimonitor:
rpimonitor depends on librrds-perl; however:
Package librrds-perl is not installed.
rpimonitor depends on libhttp-daemon-perl; however:
Package libhttp-daemon-perl is not installed.
rpimonitor depends on libhttp-daemon-ssl-perl; however:
Package libhttp-daemon-ssl-perl is not installed.
rpimonitor
Went to install the suggested dependencies, which led to further dependencies not being resolved, at which stage gave up, not wishing to disappear down a dependency hole :¬((
Try "sudo apt-get -f install"
If that fails please post the error so it's possible to debug further.
Bunchies
Sat Apr 12, 2014 1:10 am
@Xav
Thanks for this awesome program :mrgreen:
i use the dynamic.json data. my only issue is i don't know what to change the value to of the following to get what im looking for
the cpu load says "x.xx" instead of what im looking for 0 to 100
and the ram says "xxx.(a bunch of useless numbers)" instead of what im looking for is only the numbers in front if the decimal point
i tried messing with the values for both but i guess i don't know what im doing or if its even supported
another one i gave up on but don't completely care about is the up time, its in seconds instead of Days + Hours + minutes
since i run my pi as a server and a few other projects the uptime could be useful
richiepp
Sat Apr 12, 2014 1:39 pm
Thanks for this awesome little package! I've been using it for about a month now and it's great to have data to look at. One thing I've noticed that I'm not using my swap file, and I think this is a good thing. There has been a lot of talk on this forum about wearing out SD cards because of the constant read/write cycles to the swap file. It appears my system isn't using it at all. I wonder how common this is?
Thanks for this awesome tool to help us better understand our systems.
Gratitude!
Rich
Xav
Sat Apr 12, 2014 5:08 pm
Bunchies wrote:@Xav
In Linux world, the CPU load is used to determine the charge of the machine. Basically, shis is reflected the number of process waiting for an action into the CPU. This number should not exeed the number of processing unit (1 for the raspberry pi). I let you have a look on the internet to know the detail. That's why the value in not in percentage. Measuring the percentage of usage will not reflect the effective load of the CPU.
For the uptime data (and for all other data like ram...), RPi-Monitor is extracting raw data and let the client do the post processing (this is an optimization to have the fewest load impact on the raspberry). That why, in the json you have uptime in seconds and in the interface you have it is a human readable shape.
Xav
Sat Apr 12, 2014 5:17 pm
richiepp wrote:One thing I've noticed that I'm not using my swap file, and I think this is a good thing. I wonder how common this is?
While load average is reflecting the usage of the cpu, swap partition usage is reflecting the memory usage.
In a system having enough memory, swap partition usage should stay to zero.
Bunchies
Sat Apr 12, 2014 6:24 pm
Cool, makes sense
I'll look into having the json data being sent & having my PC do the math to try and get the values that way
rpiuser2016
Sat Nov 24, 2018 4:16 pm
Latest RPI Monitor cannot obtaing CPU temperature on Raspberry Pi 2B+
The value is NULL
rpiuser2016
Sat Nov 24, 2018 4:22 pm
The same problem on RPI 3 B+
Sat Nov 24, 2018 5:17 pm
Prior to your post this thread was last accessed 4 1/2 years ago, I suspect things have moved on...
bensimmo
Sat Nov 24, 2018 5:46 pm
they have and they can find out how at https://rpi-experiences.blogspot.com/
