WaltMc
python-rpi.gpio
Sat May 04, 2013 3:41 pm
I'm look for the python-rpi.gpio library. I have done several searches with no results including the Raspberry Pi forums.
I have downloaded Python 2.7.4 into my Rasp. Pi successfully. I just need the gpio libraries.
Any help would be great.
canibalimao
Re: python-rpi.gpio
Sat May 04, 2013 4:10 pm
Which SO are you using? Raspbian? If yes, you don't need to install anything, it's installed by default.
WaltMc
Re: python-rpi.gpio
Sun May 05, 2013 3:39 am
I bought the rpi in march it has "14/03" in white mask on the bottom.
With the pi@raspberrpi:-$
I enter " sudo apt-get install python-rpi.gpio "
I get "E: unable to locate package python-rpi.gpio"
"E: couldn't find any package by regex 'python-rpi.gpio"
alexeames
Re: python-rpi.gpio
Sun May 05, 2013 7:31 am
You can find it here
https://pypi.python.org/pypi/RPi.GPIO
but if you are using a recent Raspbian image it should already be on there.
You need sudo to use it though.
Check if you've got it like this...
sudo python
import RPi.GPIO as GPIO
If you don't get an error, you already have it.
CTRL+D
to exit python.
Alex Eames RasPi.TV, RasP.iO
WaltMc
Re: python-rpi.gpio
Sun May 05, 2013 7:29 pm
I've downloaded RPi.GPIO.0.5..2a.tar.gz from the link you posted
but I'm still getting an "E: Unable to locate package python-rpi.gpio"?
I'm saving this in "home/pi". Do i need to save it to a different folder?
jhvorlicky
Re: python-rpi.gpio
Sun May 05, 2013 7:54 pm
Hi WaltMc,
I found that ver 0.2.0 works just fine for my purposes - did you try this?
http://raspberry-gpio-python.googlecode ... 2.0.tar.gz
I had exactly your problem with 0.5.2a...
texy
Re: python-rpi.gpio
Sun May 05, 2013 9:21 pm
WaltMc wrote:I've downloaded RPi.GPIO.0.5..2a.tar.gz from the link you posted
after you have downloaded the gz file you need to extract it, then install it.
Alternatively, from the INSTALL,TXT file you'll file in the extracted folder, it states :
If you are using Raspbian, all you need to do to install the latest release is:
$ sudo apt-get update
$ sudo apt-get dist-upgrade
$ sudo apt-get install python-rpi.gpio python3-rpi.gpio
If you want to build your own version from this downloaded copy, make
sure that you have the Python development source installed first!
On Raspbian:
$ sudo apt-get install python-dev python3-dev
To install the module:
$ sudo python setup.py install
or
$ sudo python3 setup.py install
But as stated, there is version, maybe not the latest version, pre-installed with raspbian wheezy OS.
To check which version you have running on your system enter python with
>>> import RPi.GPIO as gpio
>>> gpio.VERSION
'0.5.0a'
Texy
