Phil Spiegel
Re: Potential power source
Sun Apr 01, 2012 9:01 am
I've bought  reels of 0.81mm OD 7/0.1mm which is rated  at 4 Amps!
(And it's not dodgy chinese manufacture or April 1st -even if it is), but form one of our RPi distributors ....
..its because its silver plated and PTFE sleeved so its the current capability at 200C!
I only plan using it for < 20mA though! (PVC sleeving would be for 60C and perhaps 0.4A?)
elsleepy
Sun Apr 01, 2012 11:28 am
can I use this minipak from horizonfuelcell its 5 volt out but don't find the A?
http://www.horizonfuelcell.com.....inipak.htm
john_wage
Sun Apr 01, 2012 11:44 am
The product description says 5 Volts up to 2W
Ampere = Watt / Volt
2W / 5V = 0.4A or 400mA
so no
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Mon Apr 02, 2012 5:11 am
The R-Pi board allegedly draws 200 ma with nothing else connected. Add a USB keyboard and mouse and you should still be below 400 ma. You won"t be able to power any other USB devices unless they come with their own power supply (e.g., an external USB hard disk drive), or you connect a powered (active) USB hub, which will also provide four, or more additional USB ports.
john_wage
Mon Apr 02, 2012 6:58 am
I wouldn't gamble on a weak power source, if your PSU at any one time even for a very brief moment comes up short of the demanded power your system will crash I guarantee it.
arm2
Mon Apr 02, 2012 8:16 pm
Then ask it do something and it reportedly draws up to 500mA(2.5W) Model A & 700mA(3.5W) Model B. Interestingly that is the wiki but not the FAQ though I'm sure it has been stated authoritvely quite a few times. This is excluding any power being drawn from the USB ports as 300mA has been stated as available before the 1Amp input fuse would blow.
pygmy_giant
Mon Apr 02, 2012 10:11 pm
oh – thats ok! 600ma should be enough for a dinky robot with nothing else attached except some solid state relays…. cant believe I got all 6 for 99p each – they"re £5+ on the net…. tempted to resell them on ebay for £7 and make a 700% profit! I think the shop staff must have put the wrong lable on as they were next to the nds silicone cases at the same price in similar packaging.
Ostendo ignarus addo scientia.
hippy
Tue Apr 03, 2012 9:06 am
700mA for Model B
500mA for Model A
According to the Wiki - http://elinux.org/Rpi_Low-leve.....eripherals
Chris.Rowland
Tue Apr 03, 2012 9:39 am
Using a weak power supply on a computer is a recipe for intense frustration.
As people have said if the power drops, even for an instant, memory and processors get corrupted.  If you are lucky it will crash, if not it will continue to work but with random code or data changes. This gives all sorts of inexplicable and inconsistent errors.
pygmy_giant
Tue Apr 03, 2012 9:51 am
Hmmm.... I know the feeling - thats what I'm like at the end of the working day. If my lipo's don't cut it I'll use them to power secondary circuits. I'm not sure any of us can be certain of the 700mA figure until its been tried and tested in different contexts. Would I be right in interprating it to mean 700mA to power standard periferals such as keyboard, mouse and hdmi out?
john_wage
Tue Apr 03, 2012 12:27 pm
@pygmy_giant
yes most likely when they came out with the 700mA recommended figure they would have taken in consideration the standard peripherals and then some.
pygmy_giant
Tue Apr 03, 2012 1:12 pm
your avatar pic reminds me of the mad nuclear scientist in th 80's film Repo Man.
john_wage
Tue Apr 03, 2012 1:34 pm
it's Duke Nukem
Subterranean
Wed Apr 04, 2012 5:04 am
My plan is to replace the regulators with some switched mode ones and make a li-ion battery pack with the 18650 cells that go into laptop batteries. Should keep me going for a decent amount of time but I'll be interested to see what sort of power decrease good efficiency regulators will bring. May look at powering a small screen with the battery pack as well, we'll have to see.
Jim Manley
Wed Apr 04, 2012 6:04 am
hippy said:
700mA for Model B
500mA for Model A
hippy,
500 and 700 ma are the maximum current ratings for the A and B boards, not minimum draw, which is 200 ma AIUI.
Ice
Wed Apr 04, 2012 6:53 am
http://www.qoqa.fr/fr/offer/3165
I've found this and I thinks it will be fine with raspberry pi but I'm not sure...
john_wage
Wed Apr 04, 2012 8:40 am
Exactly, and when you design your power supply it MUST be able to cope with the maximum peaks that the system could possibly draw, otherwise you get catastrophic results.
Jim Manley
Wed Apr 04, 2012 9:58 am
In general, designing for the max current is definitely advisable. Some of us will be running R-Pi boards in headless mode (e.g., SSH/VNC in via network, no video out, no keyboard/mouse, etc.), so, we can design for lower supply current, which will be important for parallel-processing Brambles of large numbers of R-Pi boards.
matthew1471
Wed Apr 04, 2012 10:47 am
I'm planning on using my pi as a media player with xbmc (or something similar), so it'll be sat next to my existing TV setup.
I checked the back of my Sky+HD box last night and there's a USB port - does anyone have a meter they could use to check the output? It would be great if it's got enough beans to power the pi!
pygmy_giant
Wed Apr 04, 2012 10:59 am
you can get multimeters from ebay quite cheaply...
hippy
Wed Apr 04, 2012 11:08 am
Not necessarily easy to do as it might mean destructive testing; you would have to put a known load on the USB supply pins and see what happens. A 5W 5R resistor should do the job to test 1A current draw. Note that how it behaves short term may not be how it behaves long term with 24/7 usage.
You'd really have to get Sky to comment on its USB power supplying capabilities, see what it says in the user manual, reverse engineer the circuitry, or hope someone has a spare Sky box which they don't mind risking destructive testing on. Different box models may behave differently.
Jim Manley
Wed Apr 04, 2012 5:48 pm
Nowadays, such ports are generally load-protected and if they can"t provide the needed current, they just shut down until the load is removed (I wouldn"t leave anything plugged in any longer than needed to determine whether everything was OK). However, according to the USB spec, the minimum current load a USB port has to support is 100 ma (if power is provided at all), and the most is 500 ma, so, even if the port does provide 500 ma, that"s awfully close to what the R-Pi with a keyboard and mouse/trackpad will likely draw, and if the port only provides 100 ma, fuhgeddaboudid.
matthew1471
Wed Apr 04, 2012 6:31 pm
Ok, thanks for the input!
I'll take the advice and not worry about it... I don't want to blow up my Sky box
Matrix
Wed Apr 04, 2012 9:50 pm
Would this be any good folks,
http://www.amazon.co.uk/Energy.....038;sr=8-1
Andy Williams
http://www.southportpattesting.com
mahjongg
Wed Apr 04, 2012 11:22 pm
Cheap chargers have a tendency to be badly regulated, and sometimes will output more than the (generally) maximum acceptable voltage of 5.0V + 5% = 5.25V.
That is acceptable for many charging inputs, but not for devices that want regulated 5V power, like the R-PI.
But this one seems to be OK, as it claims to be regulated to 5.2Volt.
