MediocreGus
I need help setting up WiFi.
Sun Apr 28, 2013 3:38 pm
Hi all,
I have a TP-Link TL-WN725N WiFi adapter which I bought for my Raspberry Pi, which is running Raspbian. If somebody could guide me through the process of setting it up, I will love you FOREVER.
I'm a complete noob at this though, and I'm going to need to be guided through every step of the way. I'm talking every console command and every config file here!
Also, I've already had a couple of shots at this. I'll try to get all of the stuff I played around with back to how it was.
Thanks,
Gus.
timmoore46
Re: I need help setting up WiFi.
Sun Apr 28, 2013 8:06 pm
I've got a WiFi adaptor working fine.
Pm me tomorrow and I'll dig out the details. It on an earlier thread of mine.
Tim
aelsas
Sun Apr 28, 2013 9:02 pm
as it has the rtl8192cu chipset it should run out of the box.
Just plug it in and start Wifi Config in LXDE ...
Best regards
Alex
mline
Sun Apr 28, 2013 9:12 pm
Edit file /etc/wpa_supplicant/wpa_supplicant.conf
Original (don't change this):
update_config=1
If you use WPA2 add this below:
network={
        ssid="YOUR SSID HERE"
        scan_ssid=1
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        group=TKIP
        psk="YOUR KEY HERE"
If you use WPA change your settings to this:
proto=WPA
pairwise=TKIP
group=TKIP
If (WPA2) don't work try this combination:
pairwise=CCMP
group=CCMP
or this:
pairwise=TKIP
group=TKIP
If you want to use a static ip edit file /etc/network/interfaces
Original:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
Change last line to:
iface default inet static
Add this lines below (the addresses must fit to your network!):
address 192.168.1.100
netmask 255.255.255.0
gateway 192.168.1.1
All files need to be edited with command "sudo nano FILENAME". If you edit this files on a running Pi you need to reboot to apply your changes.
Sorry for my bad english ;)
timmoore46
Mon Apr 29, 2013 9:45 am
Total easy fix here !
As Dongles cost less than a fiver, changing to dongle that works out of box makes sense !
http://www.raspberrypi.org/phpBB3/viewt ... 24#p314524
also
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... OU:GB:3160
(the easy fix is even linked into the listing.)
:D :D :D
Tim
pluggy
Tue Apr 30, 2013 6:52 am
Slightly cheaper non Pi 'branded' but with identical chipset :
http://www.ebay.co.uk/itm/261166708533? ... 1497.l2649
rasberrypip
Wed May 01, 2013 9:13 pm
I have Raspian Wheezy with WiFi config icon on the desktop. I bought the Realtek dongle from Pi Hut. Thought I had bought a duff one but then inserted the dongle into 4 port powered hub clicked on WiFi Config and entered SSID and password and Bingo, away we went. Hope this helps.
