When the Apple ][ came along in 1977, one of the many differences between it and legendary "boat anchor" S-100 systems (as Byte "Chaos Manor" columnist and science fiction author Jerry Pournelle liked to call them), such as the MITS Altair series, was the then completely-novel idea of using a switching power supply. To the uninitiated, they were strange, off-gold, anodized aluminum boxes with perforated holes to allow air to circulate and that provided a glimpse of a mysterious array of exotic components that made up an oscillator and also included a triac and a bizarre-looking small toroidal transformer. They really did look like alien technology to a population of knuckle-draggers used to buying ever-larger iron-core, wire-wound, step-down transformers and related rectifiers, capacitors, etc., to generate the +5, +12, and -12 volts at numerous amps consumed by pre-CMOS (complementary metal oxide semiconductor), pre-low-power Schottky, TTL (transistor-transistor logic) inverters, gates, counters, etc., used in microcomputers of the Pleistocene era.
The list price on those sleek, lightweight, switching puppies was around $120 in 1977 cash, which would be closer to $600 in today's inflation-scarred Samolians. That assumed you had connections to be able to buy them in single-unit quantities from a shady character in a back alley behind a bar that catered to the employees of the only major industry in Cupertino at that time, the quarry on the North edge of town (even HP hadn't been so hard-up for real estate yet that it had needed to build a campus in Cupertino, which is now the site of Apple's new "flying saucer" HQ that is under construction and should be opening next year). That the same functionality in a package half the size of a draftsman's eraser is now available for a few dollars (dimes, in 1977 money) is just astounding beyond comprehension, sorta like what the Pi is.
Arthur C. Clarke was right, "Any technology, sufficiently advanced, is indistinguishable from magic."
The best things in life aren't things ... but, a Pi comes pretty darned close!
