tom66
Need to get a web browser binary and can't use apt
Mon Apr 22, 2013 3:58 pm
My university applies a rather annoying first-time gateway which appears whenever I first connect a device to the network. I cannot access -any- DNS, because it forwards everything to the "netreg" server. The netreg server presents a html page where I must enter a username and password to continue. Once this is done, I can use everything as normal.
So, I need to download a basic web browser in order to do this, however, I cannot find one that does not require apt-get to install... which requires internet access. How do I sort this out? I would guess I need a binary that someone can provide or link to me. Any browser that lets me submit a form is fine. Any suggestions?
dom
Re: Need to get a web browser binary and can't use apt
Mon Apr 22, 2013 4:34 pm
I don't really understand the problem. The "wheezy" image contains "midori" web browser preinstalled.
http://www.raspberrypi.org/downloads
DeeJay
Mon Apr 22, 2013 4:36 pm
You haven't said what operating system you are using.
If it's Raspbian, there are 3 browsers installed by default - midori, dillo and netsurf.
I don't know how they do at forms support, but have you tried them all? Maybe you don't need to install anything to get started?
If that doesn't work, and you know what browser you want to install, there are ways of installing debian packages without direct internet access - but perhaps we can keep that until you know there is no other way.
tom66
Mon Apr 22, 2013 4:58 pm
I'm using openelec which boots straight to xbmc, but I'm able to ssh in so all I really need is a text browser like lynx.
DeeJay
Mon Apr 22, 2013 6:07 pm
I have no direct experience of OpenElec. Perhaps someone who has can help better.
In the absence of that... I can't see anything on the openelec website about modifying it. Since you mention apt-get, do you believe that it is based on debian and thus can install .deb packages?
The debian package is here - http://packages.debian.org/wheezy/lynx-cur but note that it has very long list of dependencies, so not being able to install it via apt-get looks as if it might be frustrating?
Could you temporarily get your RPi to somewhere with an internet connection you can use, just to perform the update?
tom66
Mon Apr 22, 2013 6:14 pm
It does look like openelec doesn't want modification; it doesn't have apt-get or dpkg. So, I have decided to give another OS a try, at the moment I am trying raspbmc.
sdjf
Thu Apr 25, 2013 3:34 am
OpenELEC does seem to allow add-ons, but they do not have apt-get and there are very few add-ons at this point for OpenELEC on the Raspberry Pi
http://wiki.openelec.tv/index.php?title=Main_Page
http://wiki.openelec.tv/index.php?title ... ic_Add-ons
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
dliloch
Mon Apr 29, 2013 8:53 am
hello - I was interested if anyone had directions on how to compile netsurf 3.0 from the source ..
I've been trying but seem to be missing one package after the next .. I am trying to compile under raspian.. thanks..
sdjf
Mon Apr 29, 2013 9:13 am
Someone in Arch reported compiling a version of Netsurf, maybe some of what he posted may help you
http://www.raspberrypi.org/phpBB3/viewt ... 53&t=29499
Maybe you could ask what dependency packages were needed? His is a modified version, so it may not have them all, but maybe he knows.
dliloch
Mon Apr 29, 2013 9:22 am
thanks for the quick reply ... I posted over there too.. Netsurf is much faster than midori but
it sort of does not support gmail .. as a matter of fact you may lose gmail authorization and have
to redo your passwords.. so I was hoping that v3.0 would be better ..
sdjf
Mon Apr 29, 2013 11:39 am
I have had good luck with links browser with gmail. If you want speedy access to gmail, that is one way to go, it provides the html view rather than the fancy one with all the bells and whistles. Surprised you are needing to reset your password just because of a change in browser. I visit gmail from various computers, browsers, ISPs, depending on how I go in, and never have to reset my passwords there.
There are several versions of links browser. I do not like the Elinks version, installed the links one using Arch on my Pi. But also use links browser to access gmail from other linux boxes as well without any problems. What is important is that ssl is built in to the browser, if there is no ssl in netsurf, I believe it will not get you into gmail.
cyrano
Mon Apr 29, 2013 11:45 am
sdjf wrote:Surprised you are needing to reset your password just because of a change in browser. I visit gmail from various computers, browsers, ISPs, depending on how I go in, and never have to reset my passwords there.
gMail is implementing two factor authentication, starting with the USA. So, depending on where you are from, behaviour of the gMail HTML pages might be different.
I had never before seen the SMS security feature either. But a couple of days ago, I changed browser on the same machine. Google detected the change and insisted on sending me a verification code over SMS. It's free, and fast and works very well as a security measure.
sdjf
Tue Apr 30, 2013 12:07 am
Oh that feature, I assume you mean the one where you have to give them a cellphone number? I do not have one, when I run into those popups, I give up and go back and log in from the other, regular machine. I never get far enough to need to do a password reset because SMS is a foreign thing for me.
demiswc
Mon Jun 24, 2013 6:30 pm
I have gone through 4 password changes since using netsurf on my RPi in the past 24 hours. Not Happy with Google Services at this moment in time.
