It does look good.
I did, however, notice in the "related items" section, this little gem, so caveat emptor:
http://www.dealextreme.com/p/1.....ngth-81243
In case someone is in doubt, the gem I noticed is in the same category as those passive HDMI<->VGA cables that have been pointed out here before. It will *not* work. Ever.
[At least not as advertised: "Converts VGA/SVGA signal to S-Video/RCA AV signal". It is possible that some demented equipment designer has at some point used a 15 pin D subminiature connector to carry the S-video etc. signals, but in that case it is not a VGA signal, and the cable is just a passive adapter that will only work with that hardware.]
Note that this does not mean that MiLO's find won't work perfectly, but given that the same site carries this piece of junk ... it would cause me to tread carefully.
Just my {local_currency}*.02
Kári.
