jeffherbst
IP Scanner ?
Fri Apr 19, 2013 5:20 pm
Does anyone know of a network IP scanner that will run?
I have looked at angry IP, but it seems to be i386 only.
I Pi is setup in my vacation house and I want to use it remotely to check network status of other devices there, so I really need a IP scanner.
pluggy
Re: IP Scanner ?
Fri Apr 19, 2013 8:33 pm
nmap
(sudo) apt-get update
(sudo) apt-get install nmap
I must not tread on too many sacred cows......
jeffherbst
Re: IP Scanner ?
Fri Apr 19, 2013 10:35 pm
Thanks, I also found zenmap works as well
TxRider
Re: IP Scanner ?
Sat Nov 24, 2018 2:03 am
How do I run the program?
Thanks !
JumpZero
Re: IP Scanner ?
Sat Nov 24, 2018 8:10 am
Thanks !
https://nmap.org/book/man.html
jahboater
Re: IP Scanner ?
Sat Nov 24, 2018 9:00 am
Here is an example:-
sudo nmap -sn 192.168.0.0/24
You get entries like this:
Nmap scan report for pi (192.168.0.80)
Host is up (0.100s latency).
MAC Address: B8:27:EB:95:F7:84 (Raspberry Pi Foundation)
pi-tastic
Re: IP Scanner ?
Tue Oct 22, 2019 5:20 pm
there are quite a few gems that are not for ARM yet. Angry IP would be nice!!!
nmap does the job for now.
i made a desktop shortcut for nmap.
the only issue is it runs but then closes the window right after its done!
how do i get it to stay open?
maccaps.com - bringing life to dead electronics.
