Hi guys!
This time I need help to solve a future issue. I bought a USB Hub, a D-Link DUB-H7, which is fed by a 5v 3A and provides 0.5A for each USB port. ( here's a link: http://www.dlink.com/us/en/home-solutio ... sb-2-0-hub )
I used to power the Pi by the 1st one port, using Fast-Charge mode, but i also need this hub to fed other devices such as webcam and external hdds ( in this case, the 1st two ports go in normal mode, so 0.5mA ).
I connected a lot of devices, and i suppose it's not enough, i connected:
- RaspberryPi ( at least 700mA )
- bv4111 ( Relay Controller + 8Channel Relay ) almost 650mA
- bv4618 + HD47780 ( almost 3mA )
- 8 PIR sensors HC-SR501( datasheet says 50uA for each ) ( two for now )
- DS18B20 Thermal Sensor
- MCP23017 ( it's going to arrive )
I guess that only the 8Channel Relay requires a lot of mA, the rest uses a power that the GPIO can handle without problems.. i guess..
So, what can be the solution? May I supply some of these components from the hub itself?
Is it possible to prevent to buy another one supply for my Pi? Maybe using something that I already have. Thanks for the help
