dehunt911
Unable to configure EDIMAX EW-7811Un to work on Channels 12
Tue Apr 16, 2013 6:00 pm
My EW-7811UN works fine on channels 1-11 on the 2.4 GHz band. It does not work on channels 12 or 13 as a wireless workstation.
I was wondering if anybody had experience of this and could help me with the configuration or installing an appropriate driver.
I am on the following update of Raspbian:
Linux raspberrypi 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013 armv6l
The EW-7811UN is one I bought from Amazon UK and it says on the packaging that it is for the GB as well as a number of other European countries – Serial number is *EW7811UN2ACE11487*.
There are a few interrogations below.
When I key in iwlist wlan0 frequency then Channel 13 is listed twice with the same frequency – this is the correct frequency for Channel 13 but there is no frequency for Channel 12 – 2.467 GHz. In addition I cannot connect via Channel 13 to my router when I set my router to run on Channel 13 on the 2.4 GHz band.
Also I cannot configure the frequency using iwconfig.
My router is a ZyXEL NBG5615 which is capable of wireless operation on 2.4 GHz and 5.0 GHz bands. I only need the 2.4 GHz b/g/n band but I need it to work on all 13 channels as does my router.
I can force the router to a specific channel ( I have set it to Channel 1) but I would prefer that the EW-7811UN work as it ought to work here in Europe on all 13 Channels.
What do I need to do?
I have downloaded rtl8192cu_linux_v2.0.939.20100726.tar.gz from EDIMAX support pages and have unpacked it but there are no instructions on how to install anything contained within the file.
Here is what I get:
[email protected]:~# iwlist wlan0 frequency
wlan0 13 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 13 : 2.472 GHz
Current Frequency:2.412 GHz (Channel 1)
[email protected]:~# iwconfig wlan0 channel 12 freq 2.467G commit
Error for wireless request "Commit changes" (8B00) :
SET failed on device wlan0 ; Operation not supported.
[email protected]:~# iwconfig wlan0 channel 13 freq 2.472G commit
[email protected]:/etc/wpa_supplicant# cat wpa_supplicant.conf
update_config=1
network={
ssid="myssid01"
psk="bbbbbbbb"
proto=WPA
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
# Added the following line – no effect
country=GB
dehunt911
EDIMAX EW-7811Un now works on Channels 12 & 13
Wed Apr 17, 2013 8:11 pm
SOLVED
Thanks to MrEngman
His profile is at: http://www.raspberrypi.org/phpBB3/membe ... le&u=10221
I took the following steps:
1) Logged onto RPis as pi/raspberry using Putty
2) sudo passwd root (set a root password)
3) Logged off and logged back on as root using Putty
4) Navigated to https://github.com/Hexxeh/rpi-update on my PC and performed the following steps:
4a) apt-get update
Updates wheezy to: Linux raspberrypi 3.6.11+ #408 PREEMPT Wed Apr 10 20:33:39 BST 2013 armv6l
You will need to be at close to this level or the following may not install
4b) apt-get install git-core
4c) wget http://goo.gl/1BOfJ -O /usr/bin/rpi-update && sudo chmod +x /usr/bin/rpi-update
4d) rpi-update
4e) Reboot using shutdown -r 0
According to MrEngman this installs a newer version of the rtl8192cu driver.
Results:
Channel 12 : 2.467 GHz
Current Frequency:2.472 GHz (Channel 13)
And all channels appear to work with the EW-7811Un on my Raspberry Pi.
