i followed the guide on https://github.com/icecc/icecream
i build icecc --build-native and named it in "/home/pi/" arm-linux-gnuabihf-4.6.tar.gz
when i start to compile i get this
make: /toolchain/arm-bcm2708hardfp-linux-gnueabi/bin/bcm2708hardfp-gcc: Command not found
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
CC kernel/bounds.s
/bin/sh: 1: /toolchain/arm-bcm2708hardfp-linux-gnueabi/bin/bcm2708hardfp-gcc: not found
make[1]: *** [kernel/bounds.s] Error 127
make: *** [prepare0] Error 2
[email protected] ~/linux $ gcc -v
Using built-in specs.
COLLECT_GCC=/usr/bin/gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.6/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Debian 4.6.3-14+rpi1' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
Thread model: posix
gcc version 4.6.3 (Debian 4.6.3-14+rpi1)
[email protected] ~/linux $ export
declare -x HOME="/home/pi"
declare -x ICECC_VERSION="/home/pi/arm-linux-gnuabihf-4.6.tar.gz"
BLA BLA BLA
declare -x MAIL="/var/mail/pi"
declare -x OLDPWD="/home/pi"
declare -x PATH="/usr/lib/icecc/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
declare -x PWD="/home/pi/linux"
declare -x SHELL="/bin/bash"
declare -x SHLVL="1"
declare -x SSH_CLIENT="217.86.143.228 59429 99"
declare -x SSH_CONNECTION="217.86.143.228 59429 192.168.178.29 99"
declare -x SSH_TTY="/dev/pts/2"
declare -x TERM="xterm"
declare -x USER="pi"
declare -x XDG_SESSION_COOKIE="57ae80824714b7b337db9bbc5115ac19-1365601933.753142-259693264"
