hevilp
cross compile problem
Fri Apr 05, 2013 1:09 pm
ill do that:
export CCPREFIX=/home/rasp/src/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-
make ARCH=arm CROSS_COMPILE=${CCPREFIX}
and get this
[email protected]:~/src/linux$ make ARCH=arm CROSS_COMPILE=${CCPREFIX}
make: /home/rasp/src/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc: Command not found
why it doesnt work?
aaa801
Re: cross compile problem
Fri Apr 05, 2013 2:13 pm
Whats the output of "file /home/rasp/src/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc"
hevilp
Sat Apr 06, 2013 7:54 am
pls watch the attachment.
thank you
jojopi
Sat Apr 06, 2013 8:42 am
That did not actually answer the question. Also, you have not checked whether the symlink is correct. But I assume by the fact that it is coloured in cyan and not in red that it is not broken.
You have the same problem as in this thread: http://www.raspberrypi.org/phpBB3/viewt ... 31&t=38918
xian
Sat Apr 06, 2013 8:46 am
I seem to remember having a similar problem. IIRC it was because the execute bit was not set on something. Might be the symlinks.
HTH
hevilp
Sat Apr 06, 2013 10:14 am
arm-linux-gnueabihf-gcc: symbolic link to `arm-linux-gnueabihf-gcc-4.7.2'
what is the solution??
