HavocMcG
Install Error
Tue Apr 02, 2013 12:18 am
Hello, hoping someone can help me here.
When installing a game/app/media (doesn't matter which) the installer runs and says it's successful, when I press a key to continue i get a notification the install was unsuccessful. I've tried from a fresh SD card install and updated to the latest version of the Pi Store but still the same result.
Any ideas?
DrPiD
Re: Install Error
Tue Apr 02, 2013 9:19 am
Hey,
Could you paste the error message that you receive?
Have you expanded the root partition on your SD card? If not, there are directions on running raspi-config here
Community Manager - IndieCity
HavocMcG
Re: Install Error
Tue Apr 02, 2013 2:17 pm
Thanks for replying,
I have expanded the partition, using an 8gb card. The "program could not be installed" is a notification bubble that pops up from the taskbar after the installer closes out.
DrPiD
Re: Install Error
Tue Apr 02, 2013 3:10 pm
Hmm, an odd one!
What have you tried installing?
Could you please navigate to /usr/share/indiecity/pistore/scripts and run the enablelogging.sh script. If you could then try running the Pi Store a couple of times, you should be able to find a log file at /home/USERNAME/indiecity/pistore/General.log
Also under /home/USERNAME/indiecity/pistore there should be a Scripts.log file
If you could post the contents of those or email them to [email protected] then something in there might give me an idea of what's going wrong :)
HavocMcG
Re: Install Error
Tue Apr 02, 2013 3:17 pm
Alright I'll give that a try and post the results when I'm home from work.
HavocMcG
Re: Install Error
Tue Apr 02, 2013 10:08 pm
So I fixed my problem, on accident of all things.
After logging in after initial startup I was using the command 'sudo startx' where's I should just use 'startx'.
Installs work great now.
Thanks for trying to assist a Linux noob ;)
DrPiD
Re: Install Error
Wed Apr 03, 2013 7:29 am
Glad you got the problem sorted :)
