Page 1 of 2
PiParted - Custom GParted Live CD for Pi (Version 0.04)
Posted: Mon Apr 01, 2013 6:39 pm
by SirLagz
Not sure if this is the best place to put it, but here goes !
I've customised a GParted LiveCD Iso to automatically run a script that will -
1. Grab the list of Distros from the RPI Download page
2. Let the user select which distro he wants to install
3. Select the Disk device that he wants to install it onto
4. dd the image onto the disk device.
Now this is in it's very infant stages, but I'm looking for some testers just to see if what I have works so far, as I don't have the ability to test it out at the moment.
The LiveCD will need at least 4 gigs of ram to run properly so that it can uncompress the image files.
Any takers ?
Some more info at my blog - http://sirlagz.net/2013/04/02/896/
Re: PiParted - Custom GParted for Pi
Posted: Mon Apr 01, 2013 7:40 pm
by pluggy
Tried it, it downloaded the raspdian image and extracted it ok. then offered my main HDD as the only available sd card to write it to. Unsurprisingly I declined.... Ubuntu 12.04 finds my card/reader OK.
Posted: Tue Apr 02, 2013 1:12 am
by SirLagz
darn, guess I'll need to mess around with the kernel a bit !
Can you please post a lsusb from both PiParted and Ubuntu ?
Thanks !
Posted: Tue Apr 02, 2013 1:44 am
by Joe Schmoe
4 G RAM???
Well, it is still April 1 (at least here in the US).
Posted: Tue Apr 02, 2013 1:59 am
by tonyhughes
Joe Schmoe wrote:4 G RAM???
If it's a live CD, and you don't have access to the filesystem (because it is a CD), and dont want to mess with the hard drives (because it might be windows or something you just dont want touched), then doing it all in RAM is a great idea. 4GB for downloading and uncompressing a 1.9GB image sounds normal to me.
Great idea!
Posted: Tue Apr 02, 2013 5:28 am
by SirLagz
Didn't even occur to me that it was April 1st lol.
Well, it actually needs around 2.8 gigs of ram...but who has 2.8 gigs of ram ? lol
2 gig is just to store the image in tmpfs pretty much.
other 1 gig is to run the livecd etc etc.
Posted: Tue Apr 02, 2013 8:29 am
by pluggy
SirLagz wrote:darn, guess I'll need to mess around with the kernel a bit !
Thanks !
Heres the Ubuntu 12.04 one
[email protected]:~$ lsusb
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 004: ID 058f:6364 Alcor Micro Corp. Hi-Speed 7-in-1 Flash Card Reader/Writer [Sabrent]
Bus 003 Device 002: ID 045e:0768 Microsoft Corp. Sidewinder X4
Bus 005 Device 002: ID 0458:002e KYE Systems Corp. (Mouse Systems)
Bus 001 Device 006: ID 04e8:689e Samsung Electronics Co., Ltd GT-S5670 [Galaxy Fit]
The last one isn't usually there, I'm charging my Phone.....
The Piparted may take a little longer
Posted: Tue Apr 02, 2013 8:45 am
by pluggy
The Piparted is the same, the Alcor 7in1 card reader is still there, it just doesn't see the SD card in it. On Ubuntu the SD card is /dev/sdb . The Piparted only sees /dev/sda . My machine has 6GB of RAM if thats relevent.
Posted: Tue Apr 02, 2013 8:55 am
by SirLagz
When you plug in the SD card, does anything new come up in the syslog ?
Posted: Tue Apr 02, 2013 9:03 am
by pluggy
You mean you want me to boot Piparted again ?
Shudder......
Posted: Tue Apr 02, 2013 9:26 am
by pluggy
I dunno what the Pi's most famous cat is like, but this one has a fixation with CD/DVDs and and the associated drives. If its within earshot and hears my CD drive run up, its jumps on the desk and sits on my keyboard...
Something of a trick question, Piparted doesn't have a syslog, dmesg doesn't change if I plug an SD card into the slot with Piparted. Unsurprisingly it does in Ubuntu.
Posted: Tue Apr 02, 2013 10:04 am
by SirLagz
Lol...thanks for That
Ill have to look into it further
Posted: Thu Apr 04, 2013 3:48 pm
by SirLagz
pluggy wrote:The Piparted is the same, the Alcor 7in1 card reader is still there, it just doesn't see the SD card in it. On Ubuntu the SD card is /dev/sdb . The Piparted only sees /dev/sda . My machine has 6GB of RAM if thats relevent.
You wouldn't happen to know which driver that card reader uses would you ?
Posted: Thu Apr 04, 2013 6:29 pm
by pluggy
Relevant bit from dmesg on my Ubuntu :
[    1.926552] Initializing USB Mass Storage driver...
[    1.926786] scsi2 : usb-storage 1-5:1.0
[    1.926945] usbcore: registered new interface driver usb-storage
[    1.926950] USB Mass Storage support registered.
[    2.216052] usb 3-1: new full-speed USB device number 2 using uhci_hcd
[    2.680055] usb 5-1: new low-speed USB device number 2 using uhci_hcd
[    2.925313] scsi 2:0:0:0: Direct-Access     Generic- SD/MMC           1.00 PQ: 0 ANSI: 0
[    2.925944] scsi 2:0:0:1: Direct-Access     Generic- Compact Flash    1.01 PQ: 0 ANSI: 0
[    2.926551] scsi 2:0:0:2: Direct-Access     Generic- SM/xD-Picture    1.02 PQ: 0 ANSI: 0
[    2.927306] scsi 2:0:0:3: Direct-Access     Generic- MS/MS-Pro        1.03 PQ: 0 ANSI: 0 CCS
[    2.928909] sd 2:0:0:0: Attached scsi generic sg2 type 0
[    2.929323] sd 2:0:0:1: Attached scsi generic sg3 type 0
[    2.930049] sd 2:0:0:2: Attached scsi generic sg4 type 0
[    2.930769] sd 2:0:0:3: Attached scsi generic sg5 type 0
[    2.933422] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[    2.935666] sd 2:0:0:1: [sdc] Attached SCSI removable disk
[    2.936418] sd 2:0:0:2: [sdd] Attached SCSI removable disk
[    2.937913] sd 2:0:0:3: [sde] Attached SCSI removable disk
Posted: Sat Apr 06, 2013 1:36 pm
by SirLagz
Sounds like it is picking up the reader then, just not the SD card.
Can you put the SD card in, and then plug the SD card reader in at all ?
-- Also an update on this
I'm making an option so that you can copy the zip file onto the SD card first, and then the distro will then use that zip file to flash the distro. this will be useful for those who have no internet connection when they boot PiParted.
Posted: Sun Apr 07, 2013 7:24 pm
by SirLagz
Version 0.02 released. Blog post with more details @ http://sirlagz.net/2013/04/08/piparted-v0-02/
Overview
Script now has 3 functions
1. Download from official mirror and flash
2. Get image from zip file on SD Card and flash - This assumes that your card is new card, i.e. one vfat partition, and also assumes there's only one zip file on the SD Card
3. Format SD Card back to default (one vfat partition that takes up entire card)
Posted: Mon Apr 08, 2013 7:11 am
by duberry
SirLagz wrote: Well, it actually needs around 2.8 gigs of ram...but who has 2.8 gigs of ram ? lol
i just dd a few img to SD ... ( the latest piCore-X > 512mb sd and wheezy-raspbian > 2gb sd )
using
 gunzip < $IMAGE | dd of=$DEVICE bs=1M
i did not have to extract the '.img' from archive . this worked with zip and gzip eg $IMAGE ="file.img.gz" or ="file.img.zip"
it did not use lots of ram !!!!!
maby this method can save some time / ram ?
eg only copy file.img.zip into ram then use above code after seting $IMAGE and $DEVICE as needed
*CODE shamelesly cut/moded from
tinycorelinux.net/4.x/armv6/README.txt
Re: PiParted - Custom GParted Live CD for Pi
Posted: Mon Apr 08, 2013 7:23 am
by ghans
I think you could use this directly with the output
from wget or curl , too !
ghans
Posted: Mon Apr 08, 2013 7:32 am
by SirLagz
using
Ah Nice.
Will have to try that on my low-ram laptop and verify :)
Thanks for that !
Also, if anyone would be kind enough to try and wipe their SD card using the 'Reset SD Card' option, and then make sure it works in windows, that would be brilliant !
Posted: Tue Apr 09, 2013 3:00 pm
by SirLagz
duberry wrote: using
Well, it looks like it works with PiParted :D
Time to modify everything to use that now, and now it also needs less ram !
Thanks a lot ! :)
Posted: Thu Apr 18, 2013 7:05 pm
by SirLagz
Just released version 0.03
Updated it to use the above code so now it doesn't need 4 gigs of ram anymore.
Blog post - http://sirlagz.net/2013/04/19/piparted-v0-03/
Posted: Fri Apr 19, 2013 11:03 am
by duberry
ghans wrote:I think you could use this directly with the output
ghans
i guess the potential advantage of this is that it would work on systems with less (1.5<) ram , like the pi?
disadvantages
afak using curl & pipe & dd you are not able to Checksum the image ? as it is writen 'on the fly' ..
@SirLagz (lol gd name!) glad it was usefull also i now have enough ram to give it a try ( just no cdrom .. but think i can work round that )
Posted: Fri Apr 19, 2013 11:46 am
by remsnet
My ANTI-PI-(A)Parted (c) !! has used only 64MB ram , runs debian Live CD with parted on VMbox and on my PC .
LOL :-) :o :twisted: :twisted:
Posted: Fri Apr 19, 2013 12:48 pm
by pluggy
Sorry SirLagz, version 0.03 doesn't find my sd card reader either. I didn't let it format my main hard drive "back to normal" . :)
Its not easy plugging the reader in when the card is in the slot, Whilst it is a USB device (almost all card readers are) its internally connected to the motheroard's USB. Open heart surgery I'm not in the mood for.....
Posted: Fri Apr 19, 2013 3:32 pm
by Jim Manley
pluggy wrote:I dunno what the Pi's most famous cat is like, but this one has a fixation with CD/DVDs and and the associated drives. If its within earshot and hears my CD drive run up, its jumps on the desk and sits on my keyboard.
If you listen carefully to the drive or touch just your fingernails on or in proximity to the drive, you'll feel the subharmonics on which the puss ... um, cat is placing its ... um, sensitive parts - those low-frequency oscillations are the disk being spun faster/slower depending on how far in/out the read/write head is relative to the center/edge of the disk. Think of a word that rhymes with "Pibrator" - hey, I'm trademarking that one! :D
