pluggy
Re: PiParted - Custom GParted for Pi
Fri Apr 19, 2013 3:55 pm
Jim Manley wrote:
pluggy wrote:I dunno what the Pi's most famous cat is like, but this one has a fixation with CD/DVDs and and the associated drives. If its within earshot and hears my CD drive run up, its jumps on the desk and sits on my keyboard.
If you listen carefully to the drive or touch just your fingernails on or in proximity to the drive, you'll feel the subharmonics on which the puss ... um, cat is placing its ... um, sensitive parts - those low-frequency oscillations are the disk being spun faster/slower depending on how far in/out the read/write head is relative to the center/edge of the disk. Think of a word that rhymes with "Pibrator" - hey, I'm trademarking that one! :D
You been watching some dodgy movies ? ;)
SirLagz
Re: PiParted - Custom GParted Live CD for Pi
Mon Apr 22, 2013 2:29 am
pluggy wrote:Sorry SirLagz, version 0.03 doesn't find my sd card reader either. I didn't let it format my main hard drive "back to normal" . :)
Its not easy plugging the reader in when the card is in the slot, Whilst it is a USB device (almost all card readers are) its internally connected to the motheroard's USB. Open heart surgery I'm not in the mood for.....
Ah one of those.
I'm trying to work out how I'm going to work around it so bear with me for now :)
Have you tried booting up PiParted with a SD card inserted ?
duberry wrote:
ghans wrote:I think you could use this directly with the output
from wget or curl , too !
ghans
i guess the potential advantage of this is that it would work on systems with less (1.5<) ram , like the pi?
disadvantages
afak using curl & pipe & dd you are not able to Checksum the image ? as it is writen 'on the fly' ..
@SirLagz (lol gd name!) glad it was usefull also i now have enough ram to give it a try ( just no cdrom .. but think i can work round that )
The checksum is actually for the zipfile and not the image itself, so image verification still works.
You can also 'burn' the iso to a USB stick to use PiParted off a USB stick rather than CD.
UNetBootin works for that on linux :)
SirLagz
Re: PiParted - Custom GParted Live CD for Pi (Version 0.04)
Tue Apr 23, 2013 6:25 pm
Version 0.04 has been released !
Grab it on my blog post @ http://sirlagz.net/2013/04/24/piparted-v0-04/
I believe the non-appearing SD card issue should be fixed now.
Also added an early SD card backup function, which only backs up the SD Card's partitions and not the free space.
e.g. a 4GB sd card with only 2GBs used for the partition should only have the 2GBs backed up.
Feedback would be very welcome !
SirLagz
Fri Apr 26, 2013 3:36 pm
So I've fried my SD card, so I can't test this for now.
Any volunteers to test the version that was just released ?
Upcoming features - Ability to retrieve and install unofficial distros -
If anyone would like to contribute any distros to the unofficial distros list, I'll be happy to include them
Resizing existing images - the ability to find an image and resize it.
Any other suggestions ?
pluggy
Fri Apr 26, 2013 5:30 pm
SirLagz wrote:So I've fried my SD card, so I can't test this for now.
I'm on the case. Hows about a really noobish way of editing files and copying files to the windoze disk so they can access the EXT4 partition without having to install extra stuff on their windoze box. ?
SirLagz
Fri Apr 26, 2013 6:07 pm
I like it :D
Problem is making it easy for them haha. I'll think about it though, thanks !
pluggy
Fri Apr 26, 2013 6:44 pm
Unfortunately it still doesn't find my SD cards, and Ubuntu still does....
SirLagz
Sat Apr 27, 2013 2:39 pm
Can you run a fdisk -l /dev/sdb in a terminal and then try running the PiParted script again ?
pluggy
Sat Apr 27, 2013 4:53 pm
It works if I do that. Incorporate it into the script ?
SirLagz
Sat Apr 27, 2013 5:36 pm
pluggy wrote:It works if I do that. Incorporate it into the script ?
That's what I thought I did =/
Can you run cat /bin/piparted | grep PollDisks an see if it returns a function ?
I swear I incorporated it in, unless I uploaded the wrong iso file... :oops:
pluggy
Sat Apr 27, 2013 6:07 pm
Its there. the script pipes it through awk and I never quite grasped awk.....
SirLagz
Sun Apr 28, 2013 3:43 am
pluggy wrote:Its there. the script pipes it through awk and I never quite grasped awk.....
which functio / menu selection are you using ?
pluggy
Sun Apr 28, 2013 5:40 am
I was looking at the script itself using cat . it has several instances of fdisk -l | awk********. I didn't get as far as working out which bit did what. The web browser isn't working in my copy, or I'd C&P it here running Piparted.
SirLagz
Sun Apr 28, 2013 7:40 am
pluggy wrote:I was looking at the script itself using cat . it has several instances of fdisk -l | awk********. I didn't get as far as working out which bit did what. The web browser isn't working in my copy, or I'd C&P it here running Piparted.
I have a feeling that maybe I uploaded the wrong iso lol...
There should also be lines with 'PollDisks' scattered around the functions
pluggy
Sun Apr 28, 2013 8:51 am
I fished it out so you can see what I have yourself :
http://www.pluggy.me.uk/raspberry/piparted
SirLagz
Sun Apr 28, 2013 10:57 am
hmm ok.
which way of flashing an image on are you using ? the official distro optione ?
pluggy
Sun Apr 28, 2013 12:56 pm
The Official Raspdian at the top of the list. It downloads it all and then decides the only option to write it is /dev/sda which is my main hard drive. It fails to find it on the SD reset option as well, unless I do the fdisk bit first. Once I've done that it all seems to work.
SirLagz
Sun Apr 28, 2013 1:01 pm
righto, I must have buggered something up.
thanks a lot ! I should be able to get it working for you next release then :)
sailnfool
Fri Jun 21, 2019 12:40 am
Have you given any thought to using ZRAM? I have installed this on Raspbian Stretch and it fixes all of the problems that I have had with Chrome crashing due to too many tabs open.
Andyroo
Fri Jun 21, 2019 11:05 am
The author has not been here since April 2017 - you can tell by clicking on the user name and it shows the dates.
Please do not resurrect old dead thread but start new questions / topics and link back to them.
