stevo_300
Re: Micro SD Card
Fri Mar 09, 2012 1:21 pm
I have tried to search for an answer to this, but have been unable to find a discussion.
I have a few Micro SD Cards laying around of a sufficient size, and an adapter so a standard SD card reader can view it. Would this setup work with the RPi?
Steve
grumpyoldgit
Re: Micro SD Card
Fri Mar 09, 2012 1:26 pm
Yes they will.
drgeoff
Re: Micro SD Card
Fri Mar 09, 2012 1:29 pm
Very likely but not guaranteed as there seems to be an issue with Class 10 cards.  The physical size difference between SD and micro-SD is not important.  The adaptor is purely passive; it just pads out the size and re-routes the connections.
Gert van Loo
Re: Micro SD Card
Fri Mar 09, 2012 1:31 pm
Steve,
there seem to varying experiences. We have heard of users with problems, but then we also know that not every (normal) SD-card works.
Today I programmed an image on a micro-SD card in an SD-adapter and the Raspberry-Pi booted and worked fine. (Even though the adapter was made in China ) So there is basically nothing wrong.
stevo_300
Re: Micro SD Card
Fri Mar 09, 2012 1:34 pm
Thank you for a quick reply!
Gert van Loo
Re: Micro SD Card
Fri Mar 09, 2012 2:52 pm
You're welcome.
Where do I send the bill?
Kernel
Re: Micro SD Card
Fri Mar 09, 2012 4:01 pm
Gert said:
You're welcome.
send it to Farnell!!
