Sat Mar 17, 2012 10:14 am
@nmcc:
1) It is my understanding that there could, at some level, be something resembling GRUB (at the same level of imprecision, as, say, referring to an SD card image file as "an ISO file" - heh heh), but that PXE is strictly x86 only. The idea is that someone, somewhere, will develop an SD card setup that contains the base files needed to boot, which will boot up to some kind of menu, that allows you to then transfer control to a selected partition/OS. Like Grub does on x86 systems...
2) I think the poster is referring to the idea raised in the "Crucial Model A hardware fix urgenly needed - do it now!" thread. The idea is that if the 5th wire isn't asserted, then the USB device could be a slave. Or something like that... In any case, read that thread for the details on why (according to the OP of that thread) it can only be done on the Model A.
Disclaimer: I don't write or endorse any of this stuff. I just have a good memory...
