tzdata and tzdata-java update problems
Posted: Fri Mar 22, 2013 3:54 pm
by monkeypi
Hi
I have run sudo apt-get update and sudo apt-upgrade, but seem to get the below error for the tzdata and tzdata-java
Anybody got any ideas how to clear it?
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
debconf: Perl may be unconfigured (Can't locate loadable object for module Hash::Util in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /usr/share/perl/5.14/fields.pm line 122
Compilation failed in require at /usr/share/perl/5.14/fields.pm line 122.
Compilation failed in require at /usr/share/perl5/Debconf/Log.pm line 10.
Compilation failed in require at (eval 1) line 4.
BEGIN failed--compilation aborted at (eval 1) line 4.
) -- aborting
Setting up tzdata (2013b-1) ...
Compilation failed in require at /usr/share/perl5/Debconf/Db.pm line 7.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Db.pm line 7.
Compilation failed in require at /usr/share/debconf/frontend line 6.
BEGIN failed--compilation aborted at /usr/share/debconf/frontend line 6.
dpkg: error processing tzdata (--configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of tzdata-java:
tzdata-java depends on tzdata (= 2013b-1); however:
Package tzdata is not configured yet.
dpkg: error processing tzdata-java (--configure):
dependency problems - leaving unconfigured
tzdata
tzdata-java
E: Sub-process /usr/bin/dpkg returned an error code (1)
Re: tzdata and tzdata-java update problems
Posted: Fri Mar 22, 2013 4:22 pm
by monkeypi
Don't worry - All sorted - it was a corrupt SD card :D
