omega1
SD card backup too big to restore?
Tue Mar 19, 2013 6:19 pm
Hi all,
I made a backup of my 4Gb SD card using Win32 Disk Imager and I tried to clone another 4Gb card by writing my .img to it, and it says that it wont fit!
It says 'Not enough space on disk: Size 7862272 sectors Available 7710720 sectors. Sector size:512
1) Could it be they are slightly different SD cards and have slightly less space available?
2) How can I make the .img file smaller as not all of the reported 3.9Gb of the backed yp file are used on my Pi.
Thanks in advance!
Get your Pi from here! http://bit.ly/18blVup
forumisto
Re: SD card backup too big to restore?
Tue Mar 19, 2013 7:04 pm
It is very possible that full capacity of two teorically equals card are a bite different.
maybe, you can resize the original partition with gparted
omega1
Tue Mar 19, 2013 7:25 pm
Hi, thanks for the reply...
Good point... Thank you.
I think my ideal solution would be to find out how to reduce the .img file.
Is it possible to read/modify an .img file? If so, how?
SirLagz
Fri Mar 22, 2013 2:04 am
If you're willing to try linux on your computer, you can use my script to automatically downsize the image so you can image it onto another SD card.
Script can be found here -> http://sirlagz.net/2013/03/10/script-au ... downsizer/
timmoore46
Fri Mar 22, 2013 5:26 am
Can I run this on the RPi ?
:D :D
Tim
TheQuestor
Fri Mar 22, 2013 6:43 am
if you don't want to install Linux, just get VMware player and make a virtual machine, attach the sd card or image to it and work away.
timmoore46
Fri Mar 22, 2013 7:59 am
I have Ubuntu 12.04
Very stupid question:- how do I get into root ?
I tried
sudo passwd
sudo chmod a+x autosizer.sh
sudo ./autosizer 2013-02-09-wheezy-raspian.img
and got back Error: Not an image file , or file doesn't exist
I was in my 'Home' directory.
(I assume it knows all about SD cards and won't try and compress my 1TB hard drive and taking 2 days to fail ? *LOL* *LOL*)
:D :D
Tim
SirLagz
Fri Mar 22, 2013 1:55 pm
timmoore46 wrote:I have Ubuntu 12.04
I tried
sudo passwd
:D :D
Tim
Is the 2013-02-09-wheezy-raspbian.img file in your home directory ?
This script will only resize image files themselves, so if you've backed up with dd into the image file, then you run the script on the image file itself.
It won't run itself on the running sd card just yet unfortunately.
timmoore46
Fri Mar 22, 2013 5:53 pm
Yes it was all in the home directory. I was resizing the img file I downloaded earlier today, just to test it.
The code was eactly as I wrote it in the last post.
Tim
pluggy
Fri Mar 22, 2013 6:39 pm
Easist way is to put the sd card into a linux machine and run gparted to shrink the partition by a bit. You can then re image the card. Use dd to put the image back onto the smaller card and ignore the error it gives at the end. Since the partition is within the bit it succesfully wrote it will work. If you want a 'clean solution' you could use the linux command 'truncate' to make the re partitioned image shorter and so it won't over run the size of the new card. Just don't shorten past the end of the second partition. The image is just full of null characters after the end of the second partition so losing a few doesn't matter. It not recommended you do it on a running Pi, unless you have a USB SD card reader and your'e working on the non running image in the card reader.
omega1
Sun Mar 24, 2013 9:38 am
I was actually able to resolve this bby a post I found.
My solution (as a Windows user) was to delete the latest version of Disk Imager and find (not that easy!) a previous version of Disk Imager which does not really care about sizes and quite happily just writes to the SD card regardless.
This solution worked for me.
SirLagz
Sun Mar 24, 2013 1:51 pm
timmoore46 wrote:Yes it was all in the home directory. I was resizing the img file I downloaded earlier today, just to test it.
Tim
Hrm...odd.
I might have to investigate that. So that was just the default Raspbian image wasn't it ?
Morden
Mon Feb 10, 2014 11:46 am
Which was the earlier version you used?
