gaumaugher1
Pi store will not run
Fri Mar 15, 2013 11:55 pm
Here we go again. My problem is similar but not the same as several other post so I went for a new thread. This is on a fresh install. When I ran the pi store the first time it told me to get the new version which I did but it failed. So I uninstalled with:
sudo apt-get --purge remove pistore
sudo apt-get autoremove
I then reinstalled with:
sudo apt-get install pistore
I get the following:
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  libqtwebkit4
  libqtwebkit4 pistore
0 upgraded, 2 newly installed, 0 to remove and 102 not upgraded.
Need to get 0 B/6,834 kB of archives.
After this operation, 21.2 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Selecting previously unselected package libqtwebkit4:armhf.
(Reading database ... 95100 files and directories currently installed.)
Unpacking libqtwebkit4:armhf (from .../libqtwebkit4_2.2.1-5_armhf.deb) ...
Selecting previously unselected package pistore.
Unpacking pistore (from .../pistore_1.1.16693_armhf.deb) ...
chgrp: cannot access `/usr/local/bin/indiecity/*': No such file or directory
find: `./InstalledApps/*/Full/*_reg.xml': No such file or directory
Setting up libqtwebkit4:armhf (2.2.1-5) ...
Setting up pistore (1.1.16693) ...
I can start up the Pi Store app but when I attempt to log in i get:
type Status report
message /WEB-INF/view/jsp/default/ui/casClientLoginView.jsp
description The requested resource (/WEB-INF/view/jsp/default/ui/casClientLoginView.jsp) is not available.
Apache Tomcat/6.0.28
So I am stuck. Any suggestions are appreciated.
DrPiD
Re: Pi store will not run
Mon Mar 18, 2013 10:23 am
Hmm, weird one. I've seen this before, somehow the user session gets a bit borked :\
Can you try navigating to /home/pi/indiecity/pistore and removing the userdata.bin file?
Community Manager - IndieCity
gaumaugher1
Mon Mar 18, 2013 10:25 pm
That did it. Thanks!
DrPiD
Re: Pi store will not run - Solved
Tue Mar 19, 2013 8:22 am
\o/ Hurrah :D
QBall1977
Thu Mar 21, 2013 9:14 pm
Please Please Please can you make it so that teachers (and similar) can run the PiStore through a proxy. We have no choice but to run the Pi's through a proxy. Port 9090.
____________________________________________
Looking for where to start - try Kernel Panic - http://goo.gl/EEQ5J
wyattwong
Thu Mar 28, 2013 3:59 pm
DrPiD wrote:Hmm, weird one. I've seen this before, somehow the user session gets a bit borked :\
It doesn't work for me even after I have remove the userdata.bin file. I still got the same error and cannot login to Pi Store. It is very frustrating.
Per
Mon Apr 01, 2013 5:24 pm
Same to me.
I tried several things, but noch chance.
Please help me.
