simbad
Re: Help with VGA
Mon Mar 05, 2012 10:54 pm
Hello all,
I'm new here.
I trying to connect monitor that supports only VGA with R-Pi. So I was looking for some solution to connect VGA with HDMI via DVI cables/adapters (maybe), but I'm not sure what to do.
What is the best combination to connect only VGA monitor with R-Pi?
Thank you!
spamel
Re: Help with VGA
Mon Mar 05, 2012 10:59 pm
Do a search, this has been discussed a lot in the past.
Jessie
Re: Help with VGA
You need an active converter.  Like this...http://www.monoprice.com/produ.....8;format=2
I know that this site is not in your country, the link is just for reference.
simbad
Re: Help with VGA
Mon Mar 05, 2012 11:05 pm
Is active converter only way to make it?
Jessie
Re: Help with VGA
Mon Mar 05, 2012 11:08 pm
Yes, cheap passive cables will not work with the R-Pi.
Here is a link to another... http://www.dealextreme.com/p/h.....rter-71816
simbad
Re: Help with VGA
Tue Mar 06, 2012 12:01 am
I understand.
On the end; I will use rca cable to connect it with TV.
Thank you for help. (close)
