aflfiuza
Script at startup
Fri Mar 08, 2013 11:30 pm
hello!
I have some python (.py) script's, and i need to run it at startup, how i can do it?
I need help, i can't run at startup
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Re: Script at startup
Sat Mar 09, 2013 4:56 am
Create a file named something like /etc/init.d/startup_script and enter the following into the file:
#! /bin/sh
python /home/pi/my_python.py
The actual path to your Python file and the name of the file should be substituted for /home/pi/my_python.py in the above script.
Then, make startup_script executable:
sudo chmod +x /etc/init.d/startup_script
Finally, you need to register startup_script so that it will run during startup:
sudo update-rc.d startup_script defaults
Now, restart your Pi and enjoy your Python script doing its thing.
The best things in life aren't things ... but, a Pi comes pretty darned close! :D
"Education is not the filling of a pail, but the lighting of a fire." -- W.B. Yeats
In theory, theory & practice are the same - in practice, they aren't!!!
LetHopeItsSnowing
Sat Mar 09, 2013 9:14 am
If you want some instructions head over to http://www.stuffaboutcode.com/2012/06/r ... rt-up.html
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
aflfiuza
Sun Mar 10, 2013 9:17 pm
Jim Manley wrote:Create a file named something like /etc/init.d/startup_script and enter the following into the file:
#! /bin/sh
Ok, i tryed, but when make sudo update +x /etc/init.d script_startup defaults i receive this message:
"update-rc.d: using dependency based boot sequencing
insserv: warming: script 'script_startup' missing LSB tag and overrides"
And when start rpi break at load system operative.
What is wrong?
JAMOV13
Thu Mar 14, 2013 1:16 am
I also have this problem.
DetlevSchm
Thu Mar 14, 2013 7:57 am
You did not state, whether you need the script to be run as part of the boot sequence (as descibed above by Jim), or after the GUI has been established. In the latter case, see the answer for "question 1" here: http://www.raspberrypi.org/phpBB3/viewtopic.php?t=18968. This is less complex to implement, if applicable.
As for the "LSB tags", google that and you will find a lot of complicated stuff :-).
theoB610
Thu Mar 14, 2013 9:44 am
Stick the code that you want to run in /etc/rc.local. I haven't tried it with a script, but I'm pretty sure it should work fine.
Heres a link:
http://askubuntu.com/questions/9853/how ... on-startup
