vk4tec
cgi-bin how / where
Thu Mar 07, 2013 10:35 am
Hello
I have apache2 running
I have PHP installed
How do I get the cgi-bin to work ?
Where should the directory live ?
What is needed to mod / install ?
- Andrew -
malakai
Re: cgi-bin how / where
Thu Mar 07, 2013 10:55 am
Been a while since I configured Apache but this has a lot of info tons of guides should easily be available with a search http://docs.joomla.org/Should_PHP_run_a ... _module%3F
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
vk4tec
Thu Mar 07, 2013 11:19 am
I added this into apache2.conf
# CGI-BIN
ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
<Directory "/var/www/cgi-bin">
AllowOverride None
Options +ExecCGI -Includes
Order allow,deny
Allow from all
</Directory>
still looking - this did not work
malakai
Thu Mar 07, 2013 11:23 am
Did you reboot or stop and start Apache after the change?
vk4tec
Thu Mar 07, 2013 1:25 pm
Yeah sure
service apache2 restart
Its saying 404 - file not found to a test.cgi
Path problem - looking at my openSUSE mac MINI
- Andrew -
vk4tec
Found it
Thu Mar 07, 2013 1:36 pm
The apache2 install for raspberry pi
Uses /etc/apache2/sites-available directory.
In there is a file default.
default contains the CGI directive
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
So the CGI directory is in fact /usr/lib/cgi-bin for raspberry pi
- Andrew -
redhawk
Thu Mar 07, 2013 1:39 pm
Do you have AddHandler cgi-script .cgi inside your configuration file??
What happens when you try to access the cgi-bin folder with your web browser i.e. http://192.168.1.101/cgi-bin/ (change IP to match your Pi).
Do you get access denied or not found??
Richard S.
vk4tec
Thu Mar 07, 2013 2:20 pm
Fixed and working
Wrong config file I was changing
- Andrew -
geckus
Thu May 30, 2013 2:50 am
so how do you do it.
im still getting a Internal Server Error
it is the /etc/apache2/sites-available/default
page that is holds the directives?
what else am i missing?
Thu May 30, 2013 6:28 am
geckus wrote:im still getting a Internal Server Error
Have you looked at /var/log/apache2/error.log to see what the error was?
yvonnezoe
Thu Feb 27, 2014 3:29 pm
vk4tec wrote:Fixed and working
- Andrew -
How exactly did you do it? I can't find my cgi-bin in var/www/ as well. :(
Just started my Raspberry Pi journey >> http://yvonnezoe.wordpress.com
Fri Feb 28, 2014 12:32 am
#1 Look at the access.log and error.log in /var/log/apache2
#2 It's /usr/lib/cgi-bin/ in the default configuration.
yvonnezoe
Fri Feb 28, 2014 2:58 am
DougieLawson wrote:#1 Look at the access.log and error.log in /var/log/apache2
Thanks for your reply. I found my cgi-bin under /usr/lib/ but according to this tutorial, http://www.tutorialspoint.com/python/py ... amming.htm, " the Linux server is configured to run only the scripts in the cgi-bin directory in /var/www". How can I move the cgi-bin to var/www or run my python script from /usr/lib/cgi-bin?
redhawk
Fri Feb 28, 2014 9:58 am
Everything is defined in the configuration file you need to edit that to change the folder locations.
Richard S.
john4u
Wed Feb 10, 2016 9:10 am
Hi ,
is this correct
AllowOverride None
Order allow,deny
Allow from all
</Directory>
rdmcginnes
Re: cgi-bin works! A simple solution.
Wed May 04, 2016 2:06 am
I got cgi to work on the latest version of Raspian jessie.
I had apache2 setup and working from /var/www.
Then all I did is execute the following two statements:
cd /etc/apache2/mods-enabled
sudo ln -sT ../mods-available/cgi.load cgi.load
and then I rebooted.
Notice the permissions for cgi-bin and env.pl
(a test program which prints environment variables)
pi@RPi3-0001:/usr/lib/cgi-bin $ ls -al
total 20
drwxr-xr-x 2 root root 4096 May 3 19:44 .
drwxr-xr-x 83 root root 12288 May 2 18:16 ..
-rwxr-xr-x 1 root root 218 May 3 19:44 env.pl
pi@RPi3-0001:/usr/lib/cgi-bin $ cat env.pl
#!/usr/bin/perl
print "Content-type: text/html\n\n";
print "<font size=+1>Environment</font>\n";
print "executing /usr/lib/cgi-bin/env.pl<p>";
foreach (sort keys %ENV)
print "<b>$_</b>: $ENV{$_}<br>\n";
exit;
FYI, if you are interested in accessing your
web site by name instead of by IP address (even if it keeps changing) see my free, no ad, web site at eazyip.com. Now back to testing cgi.
I entered the following into my firefox browser:
http://192.168.2.111/cgi-bin/env.pl
and got the following results:
Environment executing /usr/lib/cgi-bin/env.pl
CONTEXT_DOCUMENT_ROOT: /usr/lib/cgi-bin/
CONTEXT_PREFIX: /cgi-bin/
DOCUMENT_ROOT: /var/www/html
GATEWAY_INTERFACE: CGI/1.1
HTTP_ACCEPT: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
HTTP_ACCEPT_ENCODING: gzip, deflate
HTTP_ACCEPT_LANGUAGE: en-US,en;q=0.5
HTTP_CONNECTION: keep-alive
HTTP_HOST: 192.168.2.111
HTTP_USER_AGENT: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:45.0) Gecko/20100101 Firefox/45.0
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
QUERY_STRING:
REMOTE_ADDR: 192.168.2.106
REMOTE_PORT: 49697
REQUEST_METHOD: GET
REQUEST_SCHEME: http
REQUEST_URI: /cgi-bin/env.pl
SCRIPT_FILENAME: /usr/lib/cgi-bin/env.pl
SCRIPT_NAME: /cgi-bin/env.pl
SERVER_ADDR: 192.168.2.111
SERVER_ADMIN: webmaster@localhost
SERVER_NAME: 192.168.2.111
SERVER_PORT: 80
SERVER_PROTOCOL: HTTP/1.1
SERVER_SIGNATURE:
Apache/2.4.10 (Raspbian) Server at 192.168.2.111 Port 80
SERVER_SOFTWARE: Apache/2.4.10 (Raspbian)
scchu
Tue Oct 10, 2017 4:14 am
My Raspberry Pi 3 is using 2017-08-16-raspbian-stretch.img.
Install the Apache2 by:
sudo apt-get install apache2
Setup for use CGI by:
sudo a2enmod cgi
restart Apache2:
sudo systemctl restart apache2
create cgi file:
sudo nano /usr/lib/cgi-bin/hello.cgi
Enter lines in to hello.cgi and save:
#!/bin/bash
echo -e "Content-type: text/html\n\n"
echo "<h1>Hello World</h1>"
Change hello.cgi to be executable:
sudo chmod +x /usr/lib/cgi-bin/hello.cgi
At remote browser:
http://apache_server_IP/cgi-bin/hello.cgi
All above work for me. Good luck!!
andrewclegg
Sun Jan 21, 2018 12:42 am
I used the solution posted by scchu on my Raspberry Pi 3 and it worked perfectly.
