Kesano
RPi Rev.B - only one ROM working. Need BSD
Sun Mar 03, 2013 3:51 am
Hi there.
Buyed RPi from UK.
Rev B, 512Mb, Ethernet.
Works only one ROM - Raspbian.
Any other didn't want to work.. Tryed FreeBSD, Fedora, NetBSD builds...
Raspbian - boots good on 8Gb Class 10 SD and 4Gb class 4 microSD with adapter.
All LED works...
While trying to boot freeBSD, power LED in on, ACT LET blinks once and.... nothing happing...
Somebody have working FreeBSD distr???
Thanks a lot for your replies...
tonyhughes
Re: RPi Rev.B - only one ROM working. Need BSD
Sun Mar 03, 2013 4:42 am
Is it the Fedora ARM build for Raspberry Pi that you tried?
Kesano
Sun Mar 03, 2013 1:41 pm
Yes I am!
http://downloads.raspberrypi.org/images/
There i found all of Raspberry OS Builds...
Flashed them to SD card... Nothing happens... Then i flash Raspbian to the same SD - works fine, system boots, Ethernet, USB-ethernet works etc...
Maybe need to do something with stock config.txt?... I don't know :(((
I'm very disappointed...
pluggy
Sun Mar 03, 2013 5:28 pm
The freebsd on the link you posted works fine, just tested it, today.
freebsd-pi-r245446
http://www.pluggy.me.uk/raspberry/bsd-pi.jpg
Maybe a little more detail than "Nothing Happens" would be appropriate. We don't know what you're doing.
My monitor needs a clean.......
Sun Mar 03, 2013 8:16 pm
pluggy wrote:The freebsd on the link you posted works fine, just tested it, today.
freebsd-pi-r245446
Yes, indeed it does!
Kesano
Mon Mar 04, 2013 10:27 am
Using simple TV as monitor via RCA.
When inserting SD card (today Class 4) and plug power cable, just Power LED working...
But no output on TV... Showing @No [email protected]
LAN didn't start blinking on waiting for 5 minutes...
Spid
Mon Mar 04, 2013 10:39 am
If it works for only SD Card Image, then would say you have fubared either the SD Card, download or img copying...
http://elinux.org/RPi_Easy_SD_Card_Setup
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
Kesano
Mon Mar 04, 2013 3:13 pm
Raspbian starts normal... FreeBSD - no...
MayBe SD card ISSUE??? need to try something else???
pluggy
Mon Mar 04, 2013 6:09 pm
I tried it with a DVI-D monitor, maybe they don't enable the composite video on other distros. I don't have a suitable cable to try it on my old telly.
chadlongstaff
Tue Mar 05, 2013 7:41 pm
try setting the bootable flag on the FAT partition, found with a slackware img this wasn't set and got similar symptoms
Kesano
Wed Mar 06, 2013 12:26 am
Downloaded some FreeBSD image for RPi...
boot partitions content was diffirent... New image not works... But boot works fine...
I copied files from right boot and put them to other image (just in file manager) - The miracle!!! It's up!!! )))
But no IPFW, no kernel etc...
Thanks for all...
