# uname -a
Linux raspberrypi 3.6.11+ #385 PREEMPT Fri Mar 1 21:53:22 GMT 2013 armv6l GNU/Linux
# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 7.0 (wheezy)
Release: 7.0
Codename: wheezy
# rm -Rf /var/apt/lists/*
# rm /var/dpkg/status
# touch /var/dpkg/status
# apt-get -f update
Hit http://mirrordirector.raspbian.org wheezy InRelease
Hit http://archive.raspberrypi.org wheezy InRelease
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_US
Reading package lists... Done
# sudo apt-get -f install
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
libgcc1
The following NEW packages will be installed:
libgcc1
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/54.4 kB of archives.
After this operation, 203 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
E: Cannot get debconf version. Is debconf installed?
debconf: apt-extracttemplates failed: No such file or directory
dpkg: regarding .../libgcc1_1%3a4.7.2-5+rpi1_armhf.deb containing libgcc1:armhf, pre-dependency problem:
libgcc1 pre-depends on multiarch-support
multiarch-support is unpacked, but has never been configured.
dpkg: error processing /var/cache/apt/archives/libgcc1_1%3a4.7.2-5+rpi1_armhf.deb (--unpack):
pre-dependency problem - not installing libgcc1:armhf
debconf is /usr/bin/debconf
How do I fix this?
